Today I finally got to do a proper side-by-side comparison of an HP310
PNA and hx4705 PDA, each running SeeYou Mobile, under a bright sun and in the glider cockpit. In terms of screen performance under the Arizona sun, I could hardly tell the difference between the two. If the HP310 was easier to read, it was only slightly so. In terms of software performance, the HP310 runs circles around the hx4705, as one would expect. The release candidate version of SeeYou Mobile (RC1) still has a little tweaking left to go but the crew at Naviter has done an impressive job with it so far getting it to run on Windows CE. I still prefer touch screen systems and if and when a PNA comes along with the brightness of the ClearNav or Ultimate, it will be very hard to pass up. I should also note that most of the popup menus on the 310 were nearly impossible to read without good reading glasses. My computer readers were not enough (the reader portion of my prescription bifocal tint sunglasses). If I were looking to upgrade from an existing HP PDA (39xx, 47xx) to a PNA, I would hold off for the time being. The cost to do so would only get you some software performance increase, and that's about it. I would wait until a bigger difference in screen sunlight performance is available. If I were looking to establish a new PNA/PDA system in my glider, I would certainly recommend the HP310. You can pick them up on ebay for under $150. You'll spend more than that on the cradle, power and serial-to-Bluetooth hardware. ~ted/2NO |
Has anyone tried the Navigon with SeeYou mobile? How does it compare
in performance? The price looks competitive with the 310. -Tom |
5Z wrote:
Has anyone tried the Navigon with SeeYou mobile? How does it compare in performance? The price looks competitive with the 310. What is the reason for considering it over the already supported 310? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Feb 21, 5:35*pm, 5Z wrote:
Has anyone tried the Navigon with SeeYou mobile? *How does it compare in performance? *The price looks competitive with the 310. -Tom As has been pointed out on the Naviter forums the Navigon has 480 X 272 display, the iPAQ 310 is 800 x 480 and although the displays are small the iPAQ 310 display looks *gorgeous*. The iPAQ 310 is the PNA to have right now. -- I have two iPAQ 4700 PDAs and an iPAQ 310. Indoors the 310 blows away the 4700. The 310 uses LED backlight technology and the 4700 uses cold cathode. The color temperature is higher on the LEDs and the cold cathodes look yellowish compared to the nice white backlight on the 310. Outdoors in sunlight (but not directly on the screen) the iPAQ 310 is easier to see than either of my iPAQ 4700's. A friend who has an iPAQ 310, and iPAQ 211 and an iPAQ 4700 agrees the 310 is a bit more legible than the 4700 outdoors but says the iPAQ 211 actually just beats the 310. With any of these devices with SeeYou Mobile I turn off terrain mapping, increase default font sizes, increase line widths on maps etc. to get a display that for me is most readable. Right now the iPAQ 310 takes more messing around to get this right because some of the UI elements are a little small on such a high resolution screen - Naviter is working on tweeking many of these things. The current SeeYou Mobile "release candidate" was intend to gather UI feedback. They've done an impressive job in getting this running across so many devices. No common currently available PDA or PNA devices (with current transreflective displays) are what I'd call visible in direct sunlight. However with careful mounting. At a few hundred dollars the iPAQ 310 is essentially disposable, and I'll be happy to junk it next year if something better comes along. But I'd not be holding my breath for OLED or other technology that quickly. For serious installs you will need a K-6 Bluetooth adapter and it is going to cost about the same as an iPAQ 310 on E-Bay etc. but should outlast multiple PDAs/PNAs. If you want to run say a web browser or other utilities on the PNA and are not a heavy duty geek/hacker give up now and get a PDA. Many PNAs have only a partial Windows CE install. Many (including the iPAQ 310) don't have a command shell, some don't have a Windows CE explorer (the iPAQ 310 does), most don't have a web browser, etc. etc. Naviter's approach is these are closed boxes that you plug a SD card into and you get SeeYou Mobile and ConnectMe and that is it. Which will suit many pilots fine. Darryl |
The 480 X 272 display on my Mio C320 also looks great with See You
installed- very bright and crisp. PN's are ok for back up devices. At 02:40 22 February 2009, Darryl Ramm wrote: On Feb 21, 5:35=A0pm, 5Z wrote: Has anyone tried the Navigon with SeeYou mobile? =A0How does it compare in performance? =A0The price looks competitive with the 310. -Tom As has been pointed out on the Naviter forums the Navigon has 480 X 272 display, the iPAQ 310 is 800 x 480 and although the displays are small the iPAQ 310 display looks *gorgeous*. The iPAQ 310 is the PNA to have right now. -- I have two iPAQ 4700 PDAs and an iPAQ 310. Indoors the 310 blows away the 4700. The 310 uses LED backlight technology and the 4700 uses cold cathode. The color temperature is higher on the LEDs and the cold cathodes look yellowish compared to the nice white backlight on the 310. Outdoors in sunlight (but not directly on the screen) the iPAQ 310 is easier to see than either of my iPAQ 4700's. A friend who has an iPAQ 310, and iPAQ 211 and an iPAQ 4700 agrees the 310 is a bit more legible than the 4700 outdoors but says the iPAQ 211 actually just beats the 310. With any of these devices with SeeYou Mobile I turn off terrain mapping, increase default font sizes, increase line widths on maps etc. to get a display that for me is most readable. Right now the iPAQ 310 takes more messing around to get this right because some of the UI elements are a little small on such a high resolution screen - Naviter is working on tweeking many of these things. The current SeeYou Mobile "release candidate" was intend to gather UI feedback. They've done an impressive job in getting this running across so many devices. No common currently available PDA or PNA devices (with current transreflective displays) are what I'd call visible in direct sunlight. However with careful mounting. At a few hundred dollars the iPAQ 310 is essentially disposable, and I'll be happy to junk it next year if something better comes along. But I'd not be holding my breath for OLED or other technology that quickly. For serious installs you will need a K-6 Bluetooth adapter and it is going to cost about the same as an iPAQ 310 on E-Bay etc. but should outlast multiple PDAs/PNAs. If you want to run say a web browser or other utilities on the PNA and are not a heavy duty geek/hacker give up now and get a PDA. Many PNAs have only a partial Windows CE install. Many (including the iPAQ 310) don't have a command shell, some don't have a Windows CE explorer (the iPAQ 310 does), most don't have a web browser, etc. etc. Naviter's approach is these are closed boxes that you plug a SD card into and you get SeeYou Mobile and ConnectMe and that is it. Which will suit many pilots fine. Darryl |
On Feb 23, 8:45*am, M C wrote:
The 480 X 272 display on my Mio C320 also looks great with See You installed- very bright and crisp. *PN's are ok for back up devices. We believed you the first time :-) |
At 18:55 23 February 2009, Darryl Ramm wrote:
On Feb 23, 8:45=A0am, M C wrote: The 480 X 272 display on my Mio C320 also looks great with See You installed- very bright and crisp. =A0PN's are ok for back up devices. We believed you the first time :-) Sorry about that. |
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:28 AM |
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) | Blue Oval/Dan Edwards | Aviation Photos | 4 | January 19th 07 01:19 AM |
FS a special side by side two seater. | John Firth | Soaring | 1 | January 2nd 05 08:06 PM |
CAPSTAN SIDE BY SIDE TWO SEATERS | Chris Rowland | Soaring | 19 | July 9th 04 04:51 PM |
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? | jls | Owning | 3 | April 11th 04 04:55 PM |
