WX Works setup
Old December 4th 03, 05:21 PM
Paul Tomblin
Default WX Works setup
I can't remember if I posted this before. A guy in my club made a nice
little package for his WX Works setup. You can see some pictures at
http://xcski.com/gallery/wxworks
Paul Tomblin http://xcski.com/blogs/pt/
I think it's a beautiful day to go to the zoo and feed the ducks.
To the lions.
-- Brian Kantor
Old December 4th 03, 06:18 PM
Max T, CFI
Thanks for posting. Still looks like a lot of wires!
I'm curious, what runs off the inverter and needs AC? I would have thought
that everything in the box would run off of 12 volts (though probably not off of 24
volts depending upon what plane they're in).
Max T, MCFI
Paul Tomblin wrote in message ...
To the lions.
-- Brian Kantor
Old December 4th 03, 06:33 PM
Paul Tomblin
There's only one "wire" coming out of the box, which branches off to the
USB port on the laptop, to the ships power (cigar lighter) and the single
antenna mount.
thought that everything in the box would run off of 12 volts (though
probably not off of 24 volts depending upon what plane they're in).
If I'm reading the pictures correctly, I think that rather than attempting
to engineer a DC supply for the WX Works reciever that works directly off
the ships power, he's run the ships power into the inverter and plugged
the WXWorx "wall wart" power supply into that.
Somebody willing to cut wires and make their own power supplies could
probably make it much smaller, but I think one of Dave's goals was that he
could take the expensive stuff like the WxWorx receiver out of the box and
have it be as good as new.
Never underestimate the bandwidth of a station wagon full of
tapes hurtling down the highway.
-- Andrew Tannenbaum possibly quoting Warren Jackson
Old December 4th 03, 11:45 PM
JerryK
I am pretty sure the WxWrox unit runs on DC power. At least the one in my
friend's plane is plugged into the cigarette lighter.
Old December 4th 03, 11:48 PM
Paul Tomblin
Yes, that's why he has a 9 volt DC power supply plugged into the inverter.
As I said already.
I'm a Darwinian carnivore. I only eat things that weren't fit enough
to prevent their being killed.
-- Mike Sphar
Old December 6th 03, 07:33 AM
JerryK
"Paul Tomblin" wrote in message
attempting
off
my
As I said already.
But wait, he is going from 12 or 24 volts DC to 120 volts AC to 9 volts DC?
That just does not make sense. Go to Rat shack and get a universal voltage
convertor or build one yourself. Why go to AC?
Old December 6th 03, 12:59 PM
Nathan Young
(Paul Tomblin) wrote in message ...
Before everyone freaks out - he's got a bunch of stuff in there that
you do not need for aircraft only operations. Like the Rat Shack 9V
AC-DC regulator, and the DC-AC Inverter.
-Nathan
Old December 6th 03, 02:47 PM
Paul Tomblin
You will note from the captions on the pictures that he's also got it set
up so he can plug it into the wall when he is on the ground. I'm not sure
why he has the Inverter, I'll ask him. I do know that one of his goals
was not to cut anything up (which is why he's got long coils of wire) so
he can take it out of the box and have it as good as new (and maybe resell
it).
Information moves, or we move to it. Moving to it has rarely been
popular and is growing unfashionable; nowadays we demand that the
information come to us. -- Neal Stephenson
Old December 8th 03, 04:23 AM
Nathan Young
A lot of laptops take 16VDC as their power source, something not
readily available in the plane - so perhaps he is using the inverter
to power the AC-DC converter that powers the laptop? Sounds a bit
cumbersome, but it would work, and is more readily available than
finding a 12V-16V DC switcher.
-Nathan
My plane works with bird-power ! ! ! Karl-Hugo Weesberg Home Built 14 October 27th 04 06:53 PM
Handheld GPS Works Fine, Except in One Particular Aircraft jls Home Built 3 July 5th 04 02:35 AM
Bush's Flight Instructor Speaks Up (Ref--F-102 Air Refueling Setup) Kevin Brooks Military Aviation 6 February 11th 04 05:01 AM
WX Works Paul Tomblin Piloting 0 November 19th 03 06:35 PM
