Handheld GPS Works Fine, Except in One Particular Aircraft
Old July 4th 04, 12:27 AM
jls
Default Handheld GPS Works Fine, Except in One Particular Aircraft
When I attach it to the yoke and put the antenna on the dash over the panel,
it refuses to get any satellites--- none. Yet it works fine in another 172
and in a Taylorcraft -- and in all the other airplanes I've used it in.
Now why is that? It will work as long as the master and radios are not on
and the engine not running. It's a Trimble Flightmate Pro, ancient but
adequate for me. TIA for satisfaction of my burning curiosity.
Old July 4th 04, 12:38 AM
J. Severyn
" jls" wrote in message
panel,
172
Something in that 172 is generating a signal strong enough to "jam" the GPS.
I suspect a harmonic of the LO (local oscillator) in one of the receivers in
the aircraft. Did you try tuning the Navs, the Coms and any other receiver
(DME) to a different frequency. That will change the LO frequency and
possibly move the harmonic outside the GPS receiver's input bandwidth. Also
turn the transponder off to see if the LO in the transponder is the culprit.
If that does not work, then turn off one electronic device at a time.....and
narrow it down to the offending device. If you have a split master switch,
you can run for a short time on the aircraft battery to rule out some sort
of high frequency oscillation in the voltage regulator. Good luck hunting.
J. Severyn
Old July 4th 04, 05:17 PM
jls
"J. Severyn" wrote in message
panel,
172
on
GPS.
in
receiver
Also
culprit.
time.....and
switch,
hunting.
J. Severyn
Thanks for the helpful comment. I'll check it out.
Old July 5th 04, 02:35 AM
Jerry
There have been cases of an intermediate frequency of transponders causing
this type of interference.
Jerry in NC
panel,
172
STS AV7600 VOR Handheld aviation transceiver Fastglasair Home Built 1 May 29th 04 12:16 AM
STS AV7600 VOR Handheld John Home Built 0 May 28th 04 05:42 PM
Skunk Works!?! Richard Lamb Home Built 17 May 11th 04 10:14 PM
Any problems: headsets to handheld? Michael Horowitz Home Built 9 September 30th 03 04:57 AM
