Hi,
How long does it take for the spar shrinkage to appear on an ASW27B? I've been told that if after 5-6 years it has not yet developed, then it is safe to think that it will never really become a problem. Thanks, gabriel |
On Aug 21, 2:36*pm, Gabriel Duford wrote:
How long does it take for the spar shrinkage to appear on an ASW27B? I've been told that if after 5-6 years it has not yet developed, then it is safe to think that it will never really become a problem. Somewhat counterintuitively, spar shrinkage on the top rarely accounts for much performance degradation. Here's how I understand it from the engineer who does my aerodynamics: The spar is near the chordwise station of maximum depth, aft of which the upper surface flow is going to transition to turbulent anyhow. So if you get a .002+ whifferdill at the spar that flips it, you've lost what, maybe an inch of laminar run? Meh. Learning more effective thermalling can totally submerge that kind of performance difference. But on the bottom surface of a well-designed profile, the pressure gradient is such that you might be able to maintain laminar flow all the way back to the hinge line, and with good mylar maybe onto the control surface as well. If you have a contour disruption at the spar that trips the lower surface flow to turbulent, you're losing something like 10" or 20" of laminar run. That could be huge. Thanks, Bob K. |
On Tuesday, August 21, 2012 2:36:56 PM UTC-7, Gabriel Duford wrote:
Hi, How long does it take for the spar shrinkage to appear on an ASW27B? I've been told that if after 5-6 years it has not yet developed, then it is safe to think that it will never really become a problem. I had the wings on my 2003 -27B sanded after 3 years and nothing has come back. It was kept in the desert in case that makes a difference due to heat or lack of humidity. 9B |
O2 Bottle for ASW27B | Jim Cumiford | Soaring | 3 | January 25th 07 01:24 PM |
FS ASW27B | HL Falbaum | Soaring | 3 | December 20th 06 10:51 PM |
ASW27B | Ray Gimmey | Soaring | 1 | November 4th 06 02:41 AM |
ASW27B for Sale | Sam Fly | Soaring | 0 | September 13th 04 12:51 AM |
ASW27B polar | Chip Fitzpatrick | Soaring | 2 | March 1st 04 12:48 PM |
