According to the FAA aircraft registry, there are 20 LAK-17a registered in
the USA. I've been talking with Luca at the FES factory and he has offered what looks to like a good deal to have the FES installed in our ships. He will come to this country to do the installations if we will pay for expenses. His proposal amounts to approximately $28K per installation all inclusive provided we have a minimum of four (4) ships. I know the price will be higher for fewer ships so I would expect that it would be marginally less for more ships due to expenses being spread thinner. Is there any interest among the LAK-17 or -19 owners to have the FES factory come to the USA to modify our ships? Please reply to the author or post replies here. |
Are LAK's the only gliders which can be modified?
Ramy |
I'm guessing here to give you a quick response but I'll check with the
factory before being specific. I would think that any glider with a circular cross section where the nose is cut off for the installation would be a good candidate for a FES installation. Without a circular cross section, the fuselage could be reshaped in that area, but I wouldn't consider that an elegant solution. I would also guess that the factory currently has only done this installation on the LAK-17a and -17b and so only has installation data and experience for those models. What glider do you have? "Ramy" wrote in message ... Are LAK's the only gliders which can be modified? Ramy |
Regarding a certificated aircraft, I can only suggest that you talk with
your FSDO and the glider's manufacturer. I would think this modification could be done with a FAA Form 337, but I'd be very careful to make sure the manufacturer will approve the modification and the FAA will allow it. "Dan Marotta" wrote in message ... I'm guessing here to give you a quick response but I'll check with the factory before being specific. I would think that any glider with a circular cross section where the nose is cut off for the installation would be a good candidate for a FES installation. Without a circular cross section, the fuselage could be reshaped in that area, but I wouldn't consider that an elegant solution. I would also guess that the factory currently has only done this installation on the LAK-17a and -17b and so only has installation data and experience for those models. What glider do you have? "Ramy" wrote in message ... Are LAK's the only gliders which can be modified? Ramy |
On Wednesday, September 19, 2012 8:24:07 PM UTC-4, Dan Marotta wrote:
According to the FAA aircraft registry, there are 20 LAK-17a registered in the USA. I've been talking with Luca at the FES factory and he has offered what looks to like a good deal to have the FES installed in our ships. He will come to this country to do the installations if we will pay for expenses. His proposal amounts to approximately $28K per installation all inclusive provided we have a minimum of four (4) ships. I know the price will be higher for fewer ships so I would expect that it would be marginally less for more ships due to expenses being spread thinner. Is there any interest among the LAK-17 or -19 owners to have the FES factory come to the USA to modify our ships? Please reply to the author or post replies here. Interested! F2 Sean Fidler Ionia, MI |
They will also caution you as to Max Weight of non-lifting components. There is a battery to be added, as well as the motor. Positioned to hopefully keep the CG the same as it was before. But, when I was asking at the convention about the installation (as it would go very nicely in an HP-11. Lots of prop clearance, too!), about all I got from them was "You must be very careful about the maximum weight of non-lifting parts." This may well keep several designs from having the FES retrofitted.
Steve |
On Thursday, September 20, 2012 12:06:03 PM UTC-4, Steve Leonard wrote:
They will also caution you as to Max Weight of non-lifting components. There is a battery to be added, as well as the motor. Positioned to hopefully keep the CG the same as it was before. But, when I was asking at the convention about the installation (as it would go very nicely in an HP-11. Lots of prop clearance, too!), about all I got from them was "You must be very careful about the maximum weight of non-lifting parts." This may well keep several designs from having the FES retrofitted. Steve They suggest on their website that the ASW-19 is suitable. However, they point out that they add 45kg to the fuselage. For my particular plane, which weighs 582lbs empty and is limited to a dry weight of 805lbs because of non-lifting weight limit, that would reduce my plane down to a payload of 124lbs. The last time I was that light was in elementary school! Nonetheless this is an outstanding achievement. -- Matt |
On Sep 20, 9:06*am, Steve Leonard wrote:
...(as it would go very nicely in an HP-11. *Lots of prop clearance, too!)... Steve you're probably aware that the HP-11 was originally designed in 1962 or so to have a small engine in the nose. You can see the hazy outline in the three-view drawing in the original plans set where Dick erased the propeller. Unfortunately, the idea was way ahead of its time, and engines of the right size with the requisite horsepower did not appear for another thirty years or so and electric power was just a gleam in Tom Swift's eye. But, yeah, your primary point is well taken. With both the battery and the motor in the fuselage it is a concern that the maximum non-lifting weight dictated by wing bending moment could be exceeded. Most European gliders come from the factory with that value specified. For other gliders a bit of engineering might be required to come up with a reasonable value based on the maximum gross weight and the specified or intended weight of the wing panels. Thanks, Bob K. |
On Wednesday, September 19, 2012 7:24:07 PM UTC-5, Dan Marotta wrote:
According to the FAA aircraft registry, there are 20 LAK-17a registered in the USA. I've been talking with Luca at the FES factory and he has offered what looks to like a good deal to have the FES installed in our ships. He will come to this country to do the installations if we will pay for expenses. His proposal amounts to approximately $28K per installation all inclusive provided we have a minimum of four (4) ships. I know the price will be higher for fewer ships so I would expect that it would be marginally less for more ships due to expenses being spread thinner. Is there any interest among the LAK-17 or -19 owners to have the FES factory come to the USA to modify our ships? Please reply to the author or post replies here. If this can be done on the ASW24B, I am a definite prospect! |
On Thursday, September 20, 2012 11:24:10 AM UTC-7, slbair wrote:
On Wednesday, September 19, 2012 7:24:07 PM UTC-5, Dan Marotta wrote: According to the FAA aircraft registry, there are 20 LAK-17a registered in the USA. I've been talking with Luca at the FES factory and he has offered what looks to like a good deal to have the FES installed in our ships. He will come to this country to do the installations if we will pay for expenses. His proposal amounts to approximately $28K per installation all inclusive provided we have a minimum of four (4) ships. I know the price will be higher for fewer ships so I would expect that it would be marginally less for more ships due to expenses being spread thinner. Is there any interest among the LAK-17 or -19 owners to have the FES factory come to the USA to modify our ships? Please reply to the author or post replies here. If this can be done on the ASW24B, I am a definite prospect! I may be interested if it can be done on the 27. but, can it be done on a certified glider? Ramy |
FES (Front Electric Sustainer) | Herbert kilian | Soaring | 7 | November 12th 11 09:56 PM |
Front Electric Sustainer | Greg Arnold[_3_] | Soaring | 22 | April 19th 10 09:46 PM |
Front Electric Sustainer | LimaZulu | Soaring | 25 | November 3rd 09 02:25 PM |
would an electric sustainer be practical | Brad[_2_] | Soaring | 7 | July 24th 09 06:29 PM |
DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 12:16 AM |
