DG goes the sustainer option.
Old May 31st 04, 04:11 AM
Paul
Default DG goes the sustainer option.
Looks like DG have succumbed to market forces by annoucing they will produce
a "Turbo" version of the 808. See
http://www.dg-flugzeugbau.de/dg-808st-e.html Also has the 600kg all up
weight. Nice.
Old May 31st 04, 05:09 AM
BTIZ
the standard engines get a little anemic out here in the western high
desert.. (US)
BT
"Paul" wrote in message
produce
weight. Nice.
Old May 31st 04, 08:53 AM
Bruce Hoult
In article Ldyuc.3832$lL1.2063@fed1read03,
will produce a "Turbo" version of the 808. See
up weight. Nice.
desert.. (US)
Uhhh ... that would appear to be a non sequitur. A "turbo" is a power
improvement over a standard glider ... it's a big step down in power
(and price) from a standard engine.
-- Bruce
Old May 31st 04, 12:06 PM
Doug Hoffman
Someone please correct me if I've got this wrong. I thought the term
"Turbo" as it applies to gliders means that the sustainer engine can be
started simply by using the propeller(s): i.e., the forward movement of the
glider thru the air will cause the propeller(s) to act as a "turbine" to
start the engine(hence the term turbo). Weight savings are realized due to
lack of electric starter (and battery?).
Regards,
-Doug
up weight. Nice.
desert.. (US)
-- Bruce
Old May 31st 04, 02:15 PM
Gary Evans
That's a correct definition of TURBO. As you mentioned
they weigh less because of not having a starter and
the large battery system but also because they use
smaller direct drive engines thereby eliminating the
reduction drive.
I thought the term
'Turbo' as it applies to gliders means that the sustainer
engine can be
act as a 'turbine' to
are realized due to
Regards,
-Doug
Bruce Hoult wrote:
'BTIZ' wrote:
'Paul' wrote in message
they
will produce a 'Turbo' version of the 808. See
has the 600kg all
up weight. Nice.
in the western high
desert.. (US)
A 'turbo' is a power
step down in power
-- Bruce
Old May 31st 04, 02:16 PM
BTIZ
mmmm... I thought the 808 came with a power option... maybe I'm thinking of
the 800A.. and a turbo.. would be a step up from non turbo
BT
"Bruce Hoult" wrote in message
up weight. Nice.
desert.. (US)
-- Bruce
Old May 31st 04, 02:40 PM
Mark Navarre
Kind of like how Chevy used to call the lowest trim level on their truck line
the "Custom Deluxe" so it didn't sound like the bare bones plain jane that it
was.
The "Turbo" nickname gives a warm fuzzy to those who didn't step all the way
up to a self-launcher.
The whole concept is ironic: You are already low, and now you have to DIVE to
get your engine to start and hopefully get you home.
Sure wish I had a self-launcher (self-starter)!
Mark Navarre
2/5 black ace
LoCal, USA
remove brain to reply
Old May 31st 04, 03:36 PM
Gary Evans
With either a self launcher or turbo if you have waited
until you were low to start the engine you have made
at least two bad mistakes.
'turbo' is a power
down in power
the 'Custom Deluxe' so it didn't sound like the bare
was.
The 'Turbo' nickname gives a warm fuzzy to those who
Mark Navarre
2/5 black ace
LoCal, USA
Old June 1st 04, 02:33 AM
BTIZ
to those of us converts from powered aircraft.. a turbo would signify more
power.. not less.. a turbo charger ramming more intake air into the
manifold.. thus creating more power at high density altitudes...
But I checked DG's web to see what all the fuss is about..
BT
"BTIZ" wrote in message
news:Ldyuc.3832$lL1.2063@fed1read03...
desert.. (US)
BT
produce
weight. Nice.
Old June 1st 04, 03:50 AM
Doug Hoffman
Right. Although the usage of the term seems valid in this sustainer
application as well. I'm not sure how the term is viewed in Germany, but
here in the US it has been abused in many ways (that is, used to describe a
product that has absolutely nothing to do with a turbine. Turbo Tax,
anyone?). Sometimes I think that if I had a cat that I wanted to sell I
would call it a "turbo cat". ;-)
-Doug
Best Option for Private Pilot to Multi Commercial Instrument Ratings Hudson Valley Amusement Instrument Flight Rules 34 December 17th 04 09:25 PM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Lease with option to buy Jim Burns Owning 1 May 3rd 04 02:16 PM
Best dogfight gun? Bjørnar Bolsøy Military Aviation 317 January 24th 04 06:24 PM
