PowerFlarm BRICK range issues - are we alone????
Old October 1st 12, 04:56 PM posted to rec.aviation.soaring
Mark
Default PowerFlarm BRICK range issues - are we alone????
Three members at my club (self included) have installed PowerFlarm bricks recently. We carefully read and have complied with the antenna separation requirements in the manual. As is stands currently, the maximum xperienced communication range (Flarm to Flarm) is about 2.2 miles and it frequently drops out around 1.3-1.5 miles. Regarding PCAS operation, the only alert I have received using the PowerFlarm Brick has been the towplane at a distance of about 1000-1500 feet lateraly, same altitude. At the same time my Zaon PCAS alerted to the same towplane at a range of 2+ miles and 1000 feet below.
The three gliders are a Ventus 1, Discus 2, and a PIK. All three seem to be experiencing the same issues with very poor range. Emails to FLARM have seemed to fall on deaf ears. We're curious if we're the only ones or if others are also seeing the same issues with BRICKS. We've heard plenty from portable users who are reporting 6+ miles Flarm to Flarm and PCAS alerts approaching 5 miles. If changes to the installation will fix this, great! We just need to know what to change. The US dealer has seen pics of our installation and says the antenna installations look good. They are all on the top of the glare shields so should be excellent visibility. We'd like this to work, but if there is no option to improve the performance then sending the stuff back is certainly on the table. More testing this weekend, but at the moment it's not looking good.
Old October 1st 12, 05:24 PM posted to rec.aviation.soaring
Kimmo Hytoenen
Mark,
If the aerial is well installed, so that the "visibility" is equal in all
directions, I believe that 2-3 miles range is good. If someone
can see another glider from distance of 6 miles, then AFAIK the
antenna gain is strong into that direction, but weak in other
directions. In you make a directional antenna, you lost the
performance in all other directions. The antennas delivered with
FLARM are omni-directional, so the range analysis is spherical in
optimum case.
Have you used
http://www.flarm.com/support/analyze/index_en.html
to analyze the range?
-kh
PowerFlarm bricks
r=
antenna separation
r=
maximum xperienced
frequently
d=
only alert I
towplane at a
distanc=
time my
Zao=
and 1000 feet
be=
low.
three seem to
b=
to FLARM have
ones or if
ot=
heard plenty from
PCAS alerts
ap=
great!
W=
pics of our
ins=
are all on
th=
like
th=
then
sendi=
weekend,
bu=
Old October 1st 12, 05:38 PM posted to rec.aviation.soaring
Luke Szczepaniak
PowerFlarm users are not able to use this tool as our units do not
produce an IGC file at this point. I have a PowerFlarm brick installed
in an ASW27 and my range seems to be 4KM which is plenty for collision
avoidance, pcas and adsb ranges are definitely reduced as compared to
the portable unit that I had previously.
Luke Szczepaniak
On 10/01/2012 12:24 PM, Kimmo Hytoenen wrote:
Mark,
optimum case.
Have you used
-kh
PowerFlarm bricks
r=
antenna separation
r=
maximum xperienced
frequently
d=
only alert I
towplane at a
distanc=
time my
Zao=
and 1000 feet
be=
low.
three seem to
b=
to FLARM have
ones or if
ot=
heard plenty from
PCAS alerts
ap=
great!
W=
pics of our
ins=
are all on
th=
like
th=
then
sendi=
weekend,
bu=
Old October 1st 12, 07:00 PM posted to rec.aviation.soaring
Andy[_1_]
optimum case.
A dipole is not omni-directional. The pattern of an ideal dipole in
free space is not sherical. Why do you believe that the antennas
delivered with FLARM are omni-directional?
Andy
Old October 1st 12, 08:33 PM posted to rec.aviation.soaring
Kimmo Hytoenen
Andy, you are right, the antenna is not necessary the dipole
version.
I think that dipole antenna is omnidirectional, since it radiates
equally in all directions in plane. The radiation pattern should be
donut shape.
If antenna is 1/4 wave stick on ground plate, isn't the pattern a half
sphere?
optimum case.
Andy
Old October 1st 12, 05:49 PM posted to rec.aviation.soaring
kirk.stant
Mark, how is your config file setup?
Kirk
Old October 2nd 12, 12:23 AM posted to rec.aviation.soaring
Kirk
Kirk,
For lateral range initially I had no values in my config so the assumption is default should be maximum. Next time out I have a new config file which I've chosen 9000 meters for the lateral range for the PCAS function which equates to 5 miles. That's equivalent to the Zaon. I'd like to hope that this will help. The absolute silence from the manufacturer makes me more and more suspicious that there is yet another hardware issue going on here.
Old October 2nd 12, 02:18 AM posted to rec.aviation.soaring
Ramy
Kirk
Kirk,
For lateral range initially I had no values in my config so the assumption is default should be maximum. Next time out I have a new config file which I've chosen 9000 meters for the lateral range for the PCAS function which equates to 5 miles. That's equivalent to the Zaon. I'd like to hope that this will help. The absolute silence from the manufacturer makes me more and more suspicious that there is yet another hardware issue going on here..
I tried that. It did not make any difference...
I heard second hand that Powerflarm USA confirmed the PCAS issue is a software problem which they are going to address.
Ramy
Old October 3rd 12, 01:06 PM posted to rec.aviation.soaring
Kirk
Kirk,
The new config file which I intend to load before flying this coming weekend includes the following. I believe this would give me a 5 mile lateral range and a 3000 foot vertical range for transponder and ADSB. Take a look. Are there any settings for Flarm to Flarm range in the config options????
# Set vertical ADS-B range in meters.
# For gliders, a vertical range of +-1000m is recommended
$pflac,s,adsbvrange,1000
$PFLAC,S,ADSBRANGE,9000
# Transponder Range Variables in meters horz above vert
$PFLAC,S,PCASRANGE,9000
$PFLAC,S,PCASVRANGE,1000
Mark
Old October 1st 12, 07:36 PM posted to rec.aviation.soaring
On Monday, October 1, 2012 11:56:14 AM UTC-4, Mark wrote:
Three members at my club (self included) have installed PowerFlarm bricks recently. We carefully read and have complied with the antenna separation requirements in the manual. As is stands currently, the maximum xperienced communication range (Flarm to Flarm) is about 2.2 miles and it frequently drops out around 1.3-1.5 miles. Regarding PCAS operation, the only alert I have received using the PowerFlarm Brick has been the towplane at a distance of about 1000-1500 feet lateraly, same altitude. At the same time my Zaon PCAS alerted to the same towplane at a range of 2+ miles and 1000 feet below. The three gliders are a Ventus 1, Discus 2, and a PIK. All three seem to be experiencing the same issues with very poor range. Emails to FLARM have seemed to fall on deaf ears. We're curious if we're the only ones or if others are also seeing the same issues with BRICKS. We've heard plenty from portable users who are reporting 6+ miles Flarm to Flarm and PCAS alerts approaching 5 miles. If changes to the installation will fix this, great! We just need to know what to change. The US dealer has seen pics of our installation and says the antenna installations look good. They are all on the top of the glare shields so should be excellent visibility. We'd like this to work, but if there is no option to improve the performance then sending the stuff back is certainly on the table. More testing this weekend, but at the moment it's not looking good.
It would seem that the range you are getting is good enough to provide the anti-collision properties that this device is intended to provide, at least glider to glider. Seeing other gliders for tactical purposes is what you get beyond the range that you are reporting. Nice to have, but not getting this would not seem to be a reason to pull the plug on the use of it in your glider.
I use a single element Flarm antenna on my glare shield in my '27 and see gliders to about 4 miles or so. I don't have any feedback on PCAS function.
FWIW
UH
Video of Powerflarm brick in action Ramy Soaring 7 September 1st 12 12:51 AM
Powerflarm Brick feedback Ramy Soaring 7 August 10th 12 01:02 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM 'brick' progress? Frank Paynter[_2_] Soaring 5 November 13th 11 07:28 PM
Display for PowerFLARM brick Andy[_1_] Soaring 4 May 10th 11 02:32 PM
