Display for PowerFLARM brick
Old May 9th 11, 01:02 PM posted to rec.aviation.soaring
Andy[_1_]
Default Display for PowerFLARM brick
Some time ago potential purchasers of the (US) PowerFLARM brick were
offered the choice of the bundled display or the 57mm panel mount
display. No information on either seemed to be available from US
dealers so it was impossible to make an informed choice.
Butterfly has advised me that no English manual is available yet but
the German manual can be found he
http://www.butterfly.aero/support/Ha...D_DE_final.pdf
I could not make Babel translate it but my limited German seems to
have allowed me to answer my question on knob functionality. It
appears that the bundled display, like the 57mm display, has 2
independent rotary knobs one of which also acts as a push button
switch.
The 57mm display includes the alarm and there appears to be a menu
setting to adjust the volume.
Butterfly support advised me there is no brightness control for the
57mm display, it is always full bright. I assume the same is true of
the bundled display.
Anyone knowing how to make an internet translation, or willing to
make a human translation, please post.
Andy
Old May 10th 11, 01:08 PM posted to rec.aviation.soaring
jcarlyle
Thanks for posting the link, Andy. Unfortunately, I can't understand
it either. I'll be at Mifflin next week, though, and I'll see if I can
persuade Karl Striedieck to take a look at it and tell me what it
says.
-John
Old May 10th 11, 02:09 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
switch.
Andy
Your assumption is basically correct. As a native German speaker I
could do a translation, but I don't have the time at the moment to to a
full translation of the manual. But I am willing to answer all
questions, both as a translator for the manual, but also as a 2-year
user of the butterfly display.
Re. the display: it is a transreflective display, i.e. it has no
internal light source, It gets the light from the ambient light, and the
brighter the sun shines on it the brighter the display gets. Trere has
been no situation where I could not read the display (as I do no night
flying).
The thinner of the two rotary knobs has a push button function, an
dependent of the context you are in, there might be different action for
"short" and "long" push of the button. It takes some time to get used to
the concept, but the basic functions are quite inutitive.
In normal flight mode, the outer rotary knob chooses the range
(0.5/1.0/6km/list view), the inner rotary knob moves the cursor from one
target to the next, a short button push shows details of the target
under the cursor. A long button push enters the menu.
If you have further question, please post them here, I will try to
answer them.
Peter Scholz
ASW24 JE
Old May 10th 11, 02:30 PM posted to rec.aviation.soaring
William Elliott
display. *No information on either seemed to be available from US
have allowed me to answer my question on knob functionality. *It
switch.
57mm display, it is always full bright. *I assume the same is true of
Anyone knowing *how to make an internet translation, or willing to
Andy
flying).
answer them.
Peter Scholz
ASW24 JE
I have one of these in my cockpit that I used while flying in the
Hungary last summer. It is really very cool and adds a lot to your
situational awareness. Other displays mostly just provide you the
warning information while this one will show the FLARM aircraft around
you. I liked it an will keep using this display even though I will
have my PowerFLARM sending data to the SN-10 and Oudie.
WE
Old May 10th 11, 02:32 PM posted to rec.aviation.soaring
Andy[_1_]
switch.
Andy
flying).
answer them.
Peter Scholz
ASW24 JE
Thanks Peter.
I now realize that I reached some invalid conclusions. The document
does not include a description of the PowerFLARM bundled display, only
the currently available 57mm and rectangular displays.
So, until there is documentation available for the bundled display, it
won't be possible to make an informed choice. Maybe one day it will
be possible to have a "hands on" demonstration of the brick with both
displays.
Andy
K6 Mux and PowerFLARM example systems Paul Remde Soaring 0 November 15th 10 05:01 AM
PowerFLARM bundled display Andy[_1_] Soaring 17 November 11th 10 09:43 PM
PowerFLARM Display Update Paul Remde Soaring 2 November 11th 10 06:40 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
