Becker AR4201 mic question
Old October 9th 12, 04:04 AM posted to rec.aviation.soaring
Don[_4_]
Default Becker AR4201 mic question
I have an AR4201 that I have always used with a dynamic boom mic and I
swapped it with an AR4201 wired for a standard mic in another glider.
After sliding it in the box it receives fine and the mic keys the radio,
but I'm not getting any transmit audio. Any ideas what adjustments or
software instructions to change? Anyone else seen this problem?
Old October 9th 12, 12:00 PM posted to rec.aviation.soaring
I believe you have to modify the wiring harness. The AR 3201's mic setting could be changed by moving a jumper. Not so on the 4 4201. Mics use different pins on the back of the radio based on dynamic vs standard type.
Do you have a manual for the radio?
CP
Old October 9th 12, 02:35 PM posted to rec.aviation.soaring
Tim Mara
AR4201 will operate with either Dynamic (non-amplified) or Amplified
Dynamic, Electret and Carbon type microphones but both microphone types
reqire that the mic be wired to different pin's. check my website for the
manuals and wire diagrams http://www.wingsandwheels.com/page1.htm and on
http://www.wingsandwheels.com/useful.htm
regards
Tim
"Don" wrote in message
m...
swapped it with an AR4201 wired for a standard mic in another glider. After
sliding it in the box it receives fine and the mic keys the radio, but I'm
not getting any transmit audio. Any ideas what adjustments or software
Old October 9th 12, 04:12 PM posted to rec.aviation.soaring
JohnDeRosa
It appears that both the shield (ground) and center conductors must be wired to different pins on connector J1/P1 depending on a standard or dynamic microphone.
Standard Microphone
Pin 14 - Shield
Pin 18 - Center conductor
Dynamic Microphone
Pin 6 - Shield
Pin 5 - Center conductor
Good luck, John
Old October 9th 12, 04:10 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Monday, October 8, 2012 10:04:31 PM UTC-5, Don wrote:
I have an AR4201 that I have always used with a dynamic boom mic and I swapped it with an AR4201 wired for a standard mic in another glider. After sliding it in the box it receives fine and the mic keys the radio, but I'm not getting any transmit audio. Any ideas what adjustments or software instructions to change? Anyone else seen this problem?
Sounds like you put the radio that was in the ship with a standard mic into your ship that has a dynamic, boom mic?
Did you move just the radio, or the wire harness as well? If you just moved the radio, and not the wire harness (you say you slipped it in the box, so this implies to me that you just did a radio move, nothing else), then I would think there is a problem with the microphone. Did you change radios to see if it was a radio problem or a mic problem? Maybe your dynamic boom mic element has died. I have heard of this happening before.
Steve Leonard
Old October 9th 12, 05:15 PM posted to rec.aviation.soaring
RobKol
Don,
You can look at the example of AR4201 wiring with dynamic microphone shown here http://www.flickr.com/photos/7288548...ream/lightbox/
Microphone input uses pin 5, and microphone ground uses pin 6. If you swapped the units only, than you need to go into setup mode on the transceiver and tell it that you are using dynamic microphone now. This would be SF16 setting in the unit service mode.
AR4201 manual can be accessed at http://www.becker-avionics.com/adm/m...ced1c69916.pdf
Robert
BECKER AR4201 guts Soaring 1 April 23rd 12 08:50 PM
Becker AR4201 Low Voltage Warning Papa3[_2_] Soaring 4 February 9th 12 05:09 AM
Becker AR4201 tuning problem Hellman Soaring 2 October 17th 08 11:14 PM
Becker Radio question Fred[_4_] Soaring 7 June 22nd 08 05:06 AM
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
