Becker AR4201 Low Voltage Warning
Old February 4th 12, 11:28 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Becker AR4201 Low Voltage Warning
According to the Becker manual, the 4201 Low Voltage warning (blinking of the display) kicks in when the supply voltage drops to 10.5. I'm wondering if anyone has had a reason to independently check this out for accuracy. Reason for the question is that my Becker seems to be indicating low voltage before it "should".
I run two 12V 12AH SLA batteries (independent circuits) which I just load tested (thanks to the John DeRosa article in soaring). The newer battery shows almost new performance (6.5 hours to terminal voltage under a 1.7A load). The older one shows nearly 70%.
The average load in my glider is about 1.8A (Radio, Xponder, Clearnav and vario assuming 5% transmit and fairly frequent interrogation on the Xponder).. The radio frequently starts blinking after only a couple of hours. Nobody has complained about the transmit quality. And yeah, I know the Becker has a built in volt meter. I just never thought to turn it to that page when this happens.
Any thoughts?
P3
Old February 5th 12, 12:03 AM posted to rec.aviation.soaring
T8
On Feb 4, 6:28*pm, Papa3 wrote:
According to the Becker manual, the 4201 Low Voltage warning (blinking of the display) kicks in when the supply voltage drops to 10.5. * I'm wondering if anyone has had a reason to independently check this out for accuracy. *Reason for the question is that my Becker seems to be indicating low voltage before it "should".
*I run two 12V 12AH SLA batteries (independent circuits) which I just load tested (thanks to the John DeRosa article in soaring). *The newer battery shows almost new performance (6.5 hours to terminal voltage under a 1.7A load). * The older one shows nearly 70%.
The average load in my glider is about 1.8A (Radio, Xponder, Clearnav and vario assuming 5% transmit and fairly frequent interrogation on the Xponder). * The radio frequently starts blinking after only a couple of hours. * Nobody has complained about the transmit quality. *And yeah, I know the Becker has a built in volt meter. *I just never thought to turn it to that page when this happens.
Any thoughts?
P3
Do you use circuit breakers?
The 2A CB in my panel showed a 0.44 V voltage drop when I keyed the
transmit button on my radio. Fuses (fast blow type) are much lower
resistance than similarly rated CBs.
-Evan Ludeman / T8
Old February 5th 12, 12:14 AM posted to rec.aviation.soaring
Papa3[_2_]
Fast blow barrel fuses in the panel. Even with some line losses though, I should still be above 10.5V for the better part of 6 hours.
Old February 5th 12, 02:33 AM posted to rec.aviation.soaring
JohnDeRosa
Any thoughts?
P3
Sure seems like you should have enough power with 2x12AH batteries.
Yes, breakers can be a culprit as they are basically a tiny resistive
heater coil which, unfortunately, drops a significant voltage (lower
the amp rating, the higher the voltage drop!) - but you say you are
using fuses which is a dead short so zero volts drop. But other
things can cause a drop in voltage like a loose connection or some
corrosion somewhere in the path between battery and avionics.
Transponders can be real power hogs if interrogated frequently as
yours is. One suggestion is to have a separate battery for just the
transponder - and if that battery goes flat, then all the other
avionics will stay running.
As you surmise with your comment about the Becker voltmeter, the best
way to check if there is a true low voltage issue is to measure the
voltage at the avionics and then work backwards towards the battery
thought any connections, bus bars, switches and fuses.
Good luck. And glad you made use of my article.
- John
Old February 9th 12, 05:09 AM posted to rec.aviation.soaring
Blake Seese
The average load in my glider is about 1.8A (Radio, Xponder, Clearnav and vario assuming 5% transmit and fairly frequent interrogation on the Xponder). * The radio frequently starts blinking after only a couple of hours.. * Nobody has complained about the transmit quality. *And yeah, I know the Becker has a built in volt meter. *I just never thought to turn it to that page when this happens.
Any thoughts?
P3
using fuses which is a dead short so zero volts drop. *But other
yours is. *One suggestion is to have a separate battery for just the
Good luck. *And glad you made use of my article.
- John
Our club had the same problem, it was in the radio and Becker fixed it.
Becker AR4201 tuning problem Hellman Soaring 2 October 17th 08 11:14 PM
Low voltage warning level markp Home Built 1 December 27th 05 05:11 AM
LX5000/AR4201 interference Flavio Formosa Soaring 1 May 2nd 05 02:12 PM
FA: 12V to 24V DC voltage converter Karl Geng, N1DL Home Built 2 April 21st 05 08:48 PM
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
