Nimbus 4 redline at 45000 and 55000 feet
Old February 28th 13, 12:59 AM posted to rec.aviation.soaring
Default Nimbus 4 redline at 45000 and 55000 feet
Does anyone know the redline IAS for the Nimbus 4 at 45000 and 55000 feet? Does ballast make a difference?
Thanks
AH
Old February 28th 13, 02:15 AM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Thanks
AH
Probably somewhere below stall speed!
Old February 28th 13, 02:18 AM posted to rec.aviation.soaring
SoaringXCellence
Thanks
AH
What are you looking to do here? The IAS is always the IAS, but the Va is TAS. I assume you are trying to see how fast you can fly IAS for a TAS equal to Va.
If you can give me the Va number, I will assume standard temperature for FL450 and FL550, then using my handy E6B I can figure the IAS.
Mike
Old February 28th 13, 03:17 AM posted to rec.aviation.soaring
Frank Whiteley
Thanks
AH
No. Design considerations are generally limited to operation in the first 6000m. There are some theories though.
Try searching rec.aviation.soaring via Google Groups on Technical Soaring EAS or TAS and/or IAS
Here's one such thread
http://tinyurl.com/cxn8odb
Frank Whiteley
Old February 28th 13, 08:44 PM posted to rec.aviation.soaring
Bill D
When Klaus Ohlmann was in Colorado a year so so back he mentioned the N4D he flew to his distance record in 2003 had been "altered" by the factory to allow higher IAS at high altitudes. At the 2012 SSA convention in Reno, I asked Tilo Holighaus what Klaus was talking about.
His answer was they had taken another look at the N4D engineering and flight test data and decided the IAS altitude limitations could be eased. Apparently, Ohlmann's "alteration" was an edit to the Approved Flight Manual.
That said, there are airframe modifications which 'might' improve flutter resistance in the flight levels. Silicon oil filled hydraulic dampers installed as near as possible to the control surfaces are one possibility. Essentially, one pays the price of 'stiffer' controls in exchange for a greater flutter margin. Of course, that does nothing for airframe flutter which does not involve control surfaces.
Thanks
AH
Frank Whiteley
Old February 28th 13, 09:12 PM posted to rec.aviation.soaring
Papa3[_2_]
There were some very good discussions on flutter margins, IAS, and altitude in Homebuilder's Hall articles from the 1970s or 1980s. Searching the SSA Archive will certainly turn them up. There are some commonly used rules of thumb along the lines of x% reduction per thousand feet, but they may not be good enough for the situations you're talking about (i.e. 2% per thousand feet at 50,000 feet is...)
P3
Old February 28th 13, 05:56 PM posted to rec.aviation.soaring
Gordon Walker[_2_]
For comparison the Nimbus 2 redline reduction with altitude is
shown
http://www.gliding.co.uk/bgainfo/tec...ts/nimbus2a.pd
f
Gordon
Old February 28th 13, 08:25 PM posted to rec.aviation.soaring
Bill D
How the heck does a Nimbus 2(a) data sheet help the OP who asked about a Nimbus 4?
shown
f
Gordon
Old February 28th 13, 06:46 PM posted to rec.aviation.soaring
Francois Hersen
Fly w an instrument we give you the TAS (true airspeed) like LX9000
RC
"The trouble with weather forecasting is that it's right too often for us to
ignore it, and wrong too often for us to rely on it."
a écrit dans le message de groupe de discussion :
Thanks
AH
FS Nimbus 3 Roy Bourgeois Soaring 0 December 26th 07 07:47 PM
Redline (inspired by Gross Weight) Jose Piloting 10 July 10th 05 06:35 PM
Redline (formerly the Beater thread) EDR Piloting 11 June 15th 04 01:06 AM
-Redline Sky- A New 2 Hour Soaring DVD! P.Naton Soaring 0 March 8th 04 06:53 AM
F.S. Nimbus 3DM Tom Stowers Soaring 0 October 18th 03 07:06 PM
