Redline (formerly the Beater thread)
Old June 14th 04, 03:07 PM
EDR
Default Redline (formerly the Beater thread)
Interesting that many have not defined the origin of the placement of
the "red line" on the tachometer.
I don't know where to look it up, but I suspect it has something to do
with prop tip speed (as one poster mentioned).
Shorten the prop, lengthen the prop, change the pitch and you will
necessisarily change the placement of the redline on the tach.
Change the pistons (bore); change the rods (stroke); change the rings
(compression); change the induction system; change the exhaust (back
pressure) and you change the torque of the engine, again altering the
redline.
Old June 14th 04, 03:21 PM
Jay Honeck
Doesn't this imply that redline RPM isn't related to engine limitations?
Why would (just for example) shortening the prop allow one to raise the RPM
limit of the engine?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 14th 04, 03:42 PM
Jay Masino
I believe it's both.
It's bad to allow the prop tip to go supersonic. I believe that this is
because the shock wave reduces the efficiency of the prop. Others can
chime in on this. Shortening the prop "slows" the linear speed that the
prop tip is experiencing at a given RPM.
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old June 14th 04, 06:28 PM
Jay Honeck
RPM
Understood.
However, how is it that you can up the RPM limit of a given engine simply
because you want to keep the prop tips subsonic?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old June 14th 04, 07:41 PM
Jay Masino
You would decrease the RPM limit, not increase it, to keep the tips
subsonic.
__!__
Old June 14th 04, 08:39 PM
Jay Honeck
simply
subsonic.
Understood. If you lengthened the prop, you'd have to decrease the RPM
redline to keep the tips subsonic.
However, the part of the question I was referring to was if you *shortened*
the prop. Part of the original post implied that you would be able to
simply *increase* the engine's redline RPM if you shortened your prop,
regardless of engine limitations. I don't believe this is true.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old June 14th 04, 04:08 PM
C J Campbell
"EDR" wrote in message
It can have something to do with it, but the same engine in different
airplanes will have a different redline. The thing that changes is TBO. The
propeller chosen for that installation will be consistent with the engine
service life desired.
Old June 14th 04, 05:48 PM
EDR
In article , C J Campbell
That's right. Some airplanes have prohibited operation in the middle of
the RPM range because of harmonics. Certain models of Cessna 210's, for
example.
Old June 15th 04, 01:06 AM
I'd rather be flying
No you won't. Redline is engine speed related only. Redline has a fixed rpm
no matter what you attach or change at the output shaft (in our case a
propeller). Take the prop off and use full throttle... the engine will most
certainly reach redline, the same redline you had before you removed the
prop. Redline speed does not change. The engine has a point where spinning
it faster starts floating valves and causing damage. This is a constant
speed. If you change the pitch and/or increase size of the prop, the engine
won't be able to spin the large prop up to redline. This doesn't mean the
engine won't have huge amount of stress on it trying to do so. It won't
reach redline, but redline remains at the same speed.
Richard
redline.
Are You Flying a "Beater?" Jay Honeck Piloting 90 June 16th 04 11:38 AM
Contract Tower Program - Discussion Thread running with scissors Instrument Flight Rules 6 April 22nd 04 04:04 AM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Fuel line thread sealant Paul Lee Home Built 7 February 26th 04 12:44 AM
recovery from inverted IMC (a propos of "backup gyros" thread) Sydney Hoeltzli Piloting 4 July 15th 03 02:00 PM
