I've seen both of these in example FLARMCFG files, are they both correct?
# configure D-SUB 9 port $PFLAC,S,NMEAOUT2,61 $PFLAC,S,BAUD2,2 and # For brick, turn on output data on DB9 serial port (both GPS and FLARM). # Needed if you want this data ! # Ignored on portable. $pflac,s,nmeaout2,1 Kirk 66 |
On Friday, March 15, 2013 3:38:50 PM UTC-7, kirk.stant wrote:
I've seen both of these in example FLARMCFG files, are they both correct? # configure D-SUB 9 port $PFLAC,S,NMEAOUT2,61 $PFLAC,S,BAUD2,2 and # For brick, turn on output data on DB9 serial port (both GPS and FLARM). # Needed if you want this data ! # Ignored on portable. $pflac,s,nmeaout2,1 Kirk 66 Kirk, They are correct depending on what you want to set. $PFLAC,S,NMEAOUT2, 61 Turns on the NMEA output DB9 port 2 and uses Data Port protocol 6 , 1 means it sends sentences GPRMC, GPGGA, GPGSA plus FLARM proprietary sentences (incl. PGRMZ) $PFLAC,S,Baud2,2 Sets baud rate DB9 port 2 to 19.2K I use the first set of commands for the Brick. Richard www.craggyaero.com |
Kirk,
Richard's note below is correct. In addition, to set to unit to output all data on the RJ45 port, use: $PFLAC,S,NMEAOUT1,61 (recommended) or $PFLAC,S,NMEAOUT,61 (works OK too) Enabling the protocol 6 data is necessary for sending out ADS-B and Mode C/S data. Below is a link to a great PowerFLARM Core Configuration File Generation Tool http://www.butterfly-avionics.com/in...core-config-en The default baudrate is 19200 - which is fine for most applications. Therefore, it is not absolutely necessary to set the baud rate. Best Regards, Paul Remde Cumulus Soaring, Inc. _____________________ "Richard" wrote in message ... On Friday, March 15, 2013 3:38:50 PM UTC-7, kirk.stant wrote: I've seen both of these in example FLARMCFG files, are they both correct? # configure D-SUB 9 port $PFLAC,S,NMEAOUT2,61 $PFLAC,S,BAUD2,2 and # For brick, turn on output data on DB9 serial port (both GPS and FLARM). # Needed if you want this data ! # Ignored on portable. $pflac,s,nmeaout2,1 Kirk 66 Kirk, They are correct depending on what you want to set. $PFLAC,S,NMEAOUT2, 61 Turns on the NMEA output DB9 port 2 and uses Data Port protocol 6 , 1 means it sends sentences GPRMC, GPGGA, GPGSA plus FLARM proprietary sentences (incl. PGRMZ) $PFLAC,S,Baud2,2 Sets baud rate DB9 port 2 to 19.2K I use the first set of commands for the Brick. Richard www.craggyaero.com |
| Thread Tools | |
| Display Modes | |
| LX Zeus and PowerFLARM Brick | Gabriel Duford | Soaring | 4 | October 4th 12 10:48 PM |
| Powerflarm Brick feedback | Ramy | Soaring | 7 | August 10th 12 02:02 AM |
| PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 26th 12 12:58 AM |
| PowerFLARM 'brick' progress? | Frank Paynter[_2_] | Soaring | 5 | November 13th 11 08:28 PM |
| Display for PowerFLARM brick | Andy[_1_] | Soaring | 4 | May 10th 11 03:32 PM |
