Temperature Probe for Dell Streak
Old April 15th 13, 10:53 PM posted to rec.aviation.soaring
Dan Marotta
Default Temperature Probe for Dell Streak
Been looking on the web without much luck.
Can anyone tell me if there's a temperature probe which can be plugged into
the earphone jack on a Dell Streak 5 and will it be recognized and processed
as such by XCSoar?
I was thinking of simply moving my probe connector from the back of my
CAI302 since it's ridiculously tedious to check OAT on the 302 (10 button
presses and 5 rotation clicks!). But then I started to wonder how badly
this would affect true airspeed computations.
Old April 15th 13, 11:18 PM posted to rec.aviation.soaring
as such by XCSoar?
Far as I know, all German gliders that can carry ballast water have an outside air thermometer in the cockpit. Isn't that good enough for you? And yes, I would leave the 302 sensor alone, it is needed for computations.
Old April 16th 13, 12:25 AM posted to rec.aviation.soaring
Dan Marotta
I would like to have continuous access to OAT via one of the info boxes in
XCSoar.
into
processed
as such by XCSoar?
computations.
Old April 16th 13, 03:12 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
in XCSoar.
What will you do with the temperature information?
I also got tired of pressing buttons on my 302. I installed a digital
food thermometer in the vent duct for $16. It does a good job of reading
the air temperature, which I believe is within a degree of OAT because
it matches the 302 well.
email me)
Old April 16th 13, 04:49 PM posted to rec.aviation.soaring
Dan Marotta
Well, it's mainly for the geek in me. There's an info box that's unfed and,
frankly I like to know what's going on outside. Ever had a relief tube
freeze up? I've fixed that problem...
There is no more room on my panel for another device.
The 302 will (I think) use a standard atmospheric model to estimate
temperature in the absence of a probe but I don't want to risk ice by
relying on a standard atmosphere. When's the last time you saw 29.92? All
day? A hundred miles away? No, I want to keep the probe with the 302.
How about relying on the local forecast as someone else already suggested?
Well, if your good day is 3 kts to 6,000' MSL that should work for you but I
fly up to 18,000' MSL all year long here in NM. It's that good! BTW, I
don't carry water in the cold months. It's too hard to thermal up into the
wave in January at 11.9 psf loading.
I saw a new device - a temperature sensor attached to a 3.5mm audio plug.
It's interesting but I'd have to cut it apart to put the probe in the nose
vent and run the wire to my streak.
Finally, if my 302 craps out I'd like to have a reasonably accurate
temperature fed to the Streak for TAS calculations. It could be the
difference in getting home or not.
in XCSoar.
I also got tired of pressing buttons on my 302. I installed a digital food
thermometer in the vent duct for $16. It does a good job of reading the
air temperature, which I believe is within a degree of OAT because it
Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email
me)
Old April 18th 13, 12:00 AM posted to rec.aviation.soaring
Dan Marotta
Default Temperature Probe for Dell Streak - Question for Eric Greenwell
Hi Eric,
Please tell me exactly what thermometer you got and where. I can't find
anything suitable on the internet or at the local hardware store. Maybe I'm
just not asking the right questions.
Dan
in XCSoar.
me)
Old April 18th 13, 05:10 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 4/17/2013 4:00 PM, Dan Marotta wrote:
Hi Eric,
I'm just not asking the right questions.
I replied privately with a picture, but here are the links:
I bought it on amazon.com. Search for "digital food thermometer". This
one seems to do the same things, but looks a little different:
http://www.amazon.com/Taylor-9842-Co...ref=pd_sim_k_3
The on/off button turns it on and off; also, it will shut off
automatically in a minute or so. That's fine with me. I believe, but I'm
not positive, that this one has a real on/off button, if you don't want
it to turn off automatically.
http://tinyurl.com/cqvnnp3
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old April 18th 13, 05:24 AM posted to rec.aviation.soaring
Mike the Strike
I think we'd need one that can read a bit higher than that one for Arizona!
Mike
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more Evan Ludeman[_4_] Soaring 2 December 31st 12 12:14 AM
Dell Streak 5 available soartech[_2_] Soaring 0 November 14th 12 05:44 PM
Short review of the Dell Streak with XCSoar Max Kellermann Soaring 6 February 9th 11 04:22 PM
Location for temperature probe in ASG 29? Tuno Soaring 2 March 28th 08 06:32 AM
Outside air temperature probe dlevy Owning 9 November 7th 06 05:14 PM
