Short review of the Dell Streak with XCSoar
Old February 1st 11, 03:59 PM posted to rec.aviation.soaring
Max Kellermann
Default Short review of the Dell Streak with XCSoar
Hi,
I have decided to buy a Dell Streak 5" for XCSoar, replacing my old
iPaq hx4700. It runs with Android, not Windows CE. We will release a
"stable" version of XCSoar for Android in March or April 2011, and
this switch to Android in my own glider will give me some more
motivation to make our Android version more mature. XCSoar is
available for free on the Android Market.
The Streak arrived today, and I've installed XCSoar on it. As
expected, it is faster than my old HTC Magic. The CPU is a modern 1
GHz Snapdragon ARM chip, with good OpenGL support.
http://max.kellermann.name/gallery/f..._1024x768.html
The Streak is bigger than PDAs, but not a lot. 5 inch is just the
right size for the cockpit. Mobile phones are too small, and tablets
are too large.
The display is a transflective TFT, which looks pretty bright. The
weather is overcast today in Germany, no direct sunlight to test with.
At normal daylight, it looks much brighter than a hx4700 and a Dell
Axim x51v. It is comparable to the Altair display, but one needs to
consider that the Altair has an antireflective display, while the
Streak seems like a mirror - applying an anti-glare layer will reduce
its brightness slightly.
The Streak has a high-resolution display (800x480, same as the LX Mini
Map and iPaq 31x). The Altair has 320x240, and the other PDAs on the
photo have 640x480. An Oudie is limited to 480x272. I would not go
below 640x480, and 800x480 feels comfortable.
The display is capable of multi-touch. XCSoar doesn't have
multi-touch yet, but we will eventually implement that.
More pictures: http://max.kellermann.name/gallery/fliegen/streak/
Max
Old February 1st 11, 05:46 PM posted to rec.aviation.soaring
Mike[_8_]
On Feb 1, 8:59*am, Max Kellermann wrote:
Hi, * * * * * * * * * * * * * * * * *
iPaq hx4700. *It runs with Android, not Windows CE. *We will release a
motivation to make our Android version more mature. *XCSoar is
The Streak arrived today, and I've installed XCSoar on it. *As
expected, it is faster than my old HTC Magic. *The CPU is a modern 1
*http://max.kellermann.name/gallery/f..._1024x768.html
The Streak is bigger than PDAs, but not a lot. *5 inch is just the
right size for the cockpit. *Mobile phones are too small, and tablets
are too large.
The display is a transflective TFT, which looks pretty bright. *The
Axim x51v. *It is comparable to the Altair display, but one needs to
Map and iPaq 31x). *The Altair has 320x240, and the other PDAs on the
photo have 640x480. *An Oudie is limited to 480x272. *I would not go
The display is capable of multi-touch. *XCSoar doesn't have
More pictures:http://max.kellermann.name/gallery/fliegen/streak/
Max
Look forward to your report when the sun returns, Max.
Old February 9th 11, 12:03 PM posted to rec.aviation.soaring
Max Kellermann
The spring is coming now!
Streak vs Altair in direct sunlight:
Both displays are doing very well, but it is very hard to make good
pictures. It depends very much on the angle. You can read both
displays very well in direct sunlight, but you might have to turn them
slightly.
The Streak turns into a mirror quickly in some sun angles, but you can
still focus your eyes on the screen (within limits). At the same
angle, the Altair is not doing significantly better: instead of seeing
a small mirror image, you can see the sun spotlight all over the
screen, making it unreadable as a whole.
Max
Old February 9th 11, 03:35 PM posted to rec.aviation.soaring
Mike[_8_]
pictures. *It depends very much on the angle. *You can read both
slightly.
still focus your eyes on the screen (within limits). *At the same
Max
Looks pretty good. Is it really that much brighter than the 4700, or
is the back light off on the Ipaq?
thanks,
Old February 9th 11, 04:22 PM posted to rec.aviation.soaring
Max Kellermann
Backlight was forced to 100% on all of the devices. There is a huge
difference between hx4700 and Streak/Altair. Even more in "reality";
the dull photos don't show the difference well enough.
(Still need to experiment with anti-glare foil on the Streak)
Max
AnyWhere Map w/Dell Axim Peter Westerkamp-TBRR Owning 20 February 6th 07 02:24 PM
Who needs terrorists when we have Dell? cjcampbell Piloting 38 August 22nd 06 05:35 PM
Dell Dimension 8300 Tlewis95 Simulators 3 March 4th 04 07:50 PM
Streak Shadow david H Home Built 0 December 27th 03 10:43 PM
Streak Shadow david H Home Built 0 December 26th 03 10:22 PM
