Does anyone do an "automotive" type compression test on their aircraft
engine? I think this kind of "dynamic" test might show problems (such as valves not opening all the way), that a leakdown test would not (and vice-versa). Anyway my annual is coming up and I want to do it. I imagine something that screws in and has a long hose to the guage, so no one has to stand behind the propellor. |
You can conduct whatever you like - however your IA will require that a
leak down test be performed since it is prescribed under Part 43. Doug wrote: Does anyone do an "automotive" type compression test on their aircraft engine? I think this kind of "dynamic" test might show problems (such as valves not opening all the way), that a leakdown test would not (and vice-versa). Anyway my annual is coming up and I want to do it. I imagine something that screws in and has a long hose to the guage, so no one has to stand behind the propellor. |
On Thu, 25 Mar 2004 22:20:47 -0800, Pat Barry wrote:
You can conduct whatever you like - however your IA will require that a leak down test be performed since it is prescribed under Part 43. prove it. TC |
Pat Barry
shared these priceless pearls of wisdom: -You can conduct whatever you like - however your IA will require that a -leak down test be performed since it is prescribed under Part 43. That happens to be bull****. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Thread Tools | |
| Display Modes | |
| Compression loss on cylinder when rings line up Truth of fiction? | test it | Home Built | 10 | May 11th 04 09:11 PM |
| Compression Tests | Doug | Owning | 10 | March 27th 04 07:17 PM |
| Compression Tests | Doug | Aerobatics | 4 | March 27th 04 06:29 AM |
| Compression Tests | Doug | General Aviation | 5 | March 27th 04 06:29 AM |
| Not Particularly Impressed with Tuskegee Airmen Propaganda. | The Enlightenment | Military Aviation | 25 | July 11th 03 10:01 PM |
