Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Compression Tests
Old March 22nd 04, 04:51 PM
Doug
Default Compression Tests
Does anyone do an "automotive" type compression test on their aircraft
engine? I think this kind of "dynamic" test might show problems (such
as valves not opening all the way), that a leakdown test would not
(and vice-versa). Anyway my annual is coming up and I want to do it. I
imagine something that screws in and has a long hose to the guage, so
no one has to stand behind the propellor.
Old March 26th 04, 07:20 AM
Pat Barry
You can conduct whatever you like - however your IA will require that a
leak down test be performed since it is prescribed under Part 43.
Old March 27th 04, 12:08 AM
prove it.
TC
Old March 27th 04, 06:29 AM
Jim Weir
Pat Barry
-You can conduct whatever you like - however your IA will require that a
-leak down test be performed since it is prescribed under Part 43.
That happens to be bull****.
http://www.rst-engr.com
