Cirrus BRS deployment
Old April 11th 04, 12:25 PM
Dan Luke
Default Cirrus BRS deployment
http://makeashorterlink.com/?L10433EF7
Old April 11th 04, 01:25 PM
Dennis O'Connor
Just reported on Aero News Net: Another Cirrus deployed it's chute when ALL
OF THE ELECTRONICS went out leaving the pilot stranded above an overcast...
The article cites recent maintenance of some sort... The issue here is
having all your eggs in one basket... I betcha the factory will say that it
is impossible for everything to fail at once - apparently they never met
Bubba the Mechanic... and just wait till you have your FADEC go poop on
take off...
Once all the magic smoke leaks out of those electronic chip thingies, life
is a bitch... Do not bet your life with a GA airplane that has a total
electronic panel... You still need a few steam gauges, and a spare
nav/com/ils on the back up battery, and at least one vacuum gyro...
denny
Old April 11th 04, 01:56 PM
Dan Luke
thingies, life is a bitch... Do not bet your life with a GA
airplane that has a total electronic panel... You still need a
few steam gauges, and a spare nav/com/ils on the back up
Don't Cirruses have backups to the PFD?
Dan
C172RG at BFM
(remove pants to reply by email)
Old April 11th 04, 02:02 PM
ISLIP
yes they do, in the bolster just below the PFD
John
Old April 11th 04, 02:35 PM
C J Campbell
"Dennis O'Connor" wrote in message
ANN is the National Enquirer of aviation news. The pilot of this particular
Cirrus radioed for help, so his electrical system did not fail.
Might come as a bit of a shock to you, but Cirrus has backup instruments. So
do the new Cessnas.
Old April 12th 04, 10:47 AM
Cub Driver
Nor did the Propwash say it did! See my post under another title,
quoting from the article.
The instruments failed "one by one", not the electrical system.
I enjoy the heck out of Propwash, and read it every morning in the
form of an email newsletter. (Skip through it, I should say; there's
too much to read.)
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! blog www.vivabush.org
Old April 11th 04, 06:20 PM
Thomas Borchert
Dennis,
You should go work for the NTSB, since you're clairvoyant an accident
causes.
is a bitch...
Once something fails, the regulation-mandated back-up kicks in. It doesn't
matter whether that's vacuum, a second battery or whatever else. There's
nothing inherently "better" about steam gauges - except they satisfy
reluctance in the face of progress. We'd still be living on trees if
everybody had that mindset.
Thomas Borchert (EDDH)
Old April 11th 04, 06:47 PM
Tony Cox
"Thomas Borchert" wrote in message
We have backup trees in the front yard which we can
climb into if the house becomes uninhabitable for some
reason.
Old April 11th 04, 07:08 PM
Bill Denton
Assume you are in an automobile, boat, or locomotive with a glass cockpit,
and you have a total failure of the glass cockpit.
You close the throttle and/or apply the brakes and come to a stop. No big
deal.
But if you are in an aircraft and have a total glass cockpit failure you
have a major problem.
Contrary to your statement, there is something "better" about steam gauges:
a history. With steam gauges we have a history, we know about when they will
fail and what the failure points will probably be.
But with a glass cockpit, the only failure information we have is
computer-projected, we don't really know much about what their in-service
failure history will be.
Prudence would dictate not only that you back up an unproved system, but
that you back it up with a proved system.
Five years or so down the road, when we have some realistic, real-world
failure data, you will probably see pilots becoming more receptive to glass
cockpits. But until more service data is built up, a healthy dose of caution
is in order...
Dennis,
causes.
life
is a bitch...
Old April 11th 04, 08:09 PM
Peter Gottlieb
Unless you're completely immersed in IMC, even a "total failure" of a glass
cockpit should be more of an inconvenience than a safety issue. And if
you're talking about those IMC conditions, then you already have some
complex systems in use that you rely on which could just as easily fail as
the glass versions.
"Bill Denton" wrote in message
deal.
gauges:
will
glass
caution
is in order...
Dennis,
causes.
life
is a bitch...
doesn't
North Korea Denounces US Stealth Bomber Deployment Otis Willie Military Aviation 0 July 2nd 04 09:20 PM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
Cirrus Airframe Life Limits Dave Owning 16 April 27th 04 05:58 PM
C-130 Unit Completes Two Year Deployment Otis Willie Military Aviation 0 September 30th 03 10:04 PM
Airmen gear up for another 120-day deployment Otis Willie Military Aviation 0 September 24th 03 12:04 AM
