Airmen gear up for another 120-day deployment
Old September 24th 03, 01:04 AM
Otis Willie
Default Airmen gear up for another 120-day deployment
(EXCERPT) By Jennifer H. Svan, Stars and Stripes Pacific edition,
Wednesday, September 24, 2003
YOKOTA AIR BASE, Japan — As the Air Force scales back its
forward-operating bases, deployments under the Aerospace Expeditionary
Force construct should return to normal by March 2004, Pacific Air
Forces officials said Monday.
But before then, hundreds of PACAF airmen are gearing up to deploy in
November under AEF Silver, the second of two transitional, 120-day
cycles designed to return the schedule to a steady-state rotation.
Operation Enduring Freedom and the war in Iraq forced the service into
a contingency mode, breaking the 90-day deployment schedule, Air Force
officials said.
“If you didn’t deploy, be prepared to do so,” said Tech. Sgt. James
Parris, expeditionary combat support manager for AEF-Pacific Branch.
Parris is a member of the PACAF Aerospace Expeditio...
U.S. and friendly nation laws prohibit fully reproducing
copyrighted material. In abidance with our laws this report
cannot be provided in its entirety. However, you can read it
in full today, 23 Sep 2003, at the following URL. (COMBINE
the following lines into your web browser.) The
subject/content of this report is not necessarily the
viewpoint of the distributing Library. This report is provided
for your information and discussion.
http://www.estripes.com/article.asp?...&article=17666
Otis Willie
Associate Librarian
The American War Library
http://www.americanwarlibrary.com
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Landing gear door operation Elliot Wilen Military Aviation 11 July 8th 03 04:30 AM
