Top ten glider trailer features?
Old November 27th 13, 03:51 AM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Default Top ten glider trailer features?
Hello,
I am in the early stages of building a Luebke patterned clamshell trailer for my Schempp-Hirth SHK. The trailer is an aluminum sheathed steel frame 'interpretation' of the cobra and comet style trailers. I have been paying attention to every glider trailer I've been around for the last few years, with the intention of incorporating the best features. Some of these features are;
Tracks and captured wing root dollies with adjustable tension hold down
brackets for the spar root (seen in a cobra containing a ventus)
Captured aluminum ramp with fold over center track, with either hydraulic
or double screw jack height adjustment (cobra again).
Pivoting lower carriage wheels on belly support dolly (cobra).
Drop down tailgate which provides a braced repeatable height of tail end
of trailer for rigging and derigging.
Front access hatch, ventilators, spare tire access when loaded.
Good lights with some lights down the length of the trailer.
Storage space for all the ground handling gear.
So, what am I missing or forgetting? Does anyone have any comments on favorite features or also, features which should be avoided at all costs? I want to eliminate those unforeseeable miserable items which pinch fingers, rash gliders, and detract from the chore of rigging and trailering a glider. I would also like to have a system which uses the least amount of loose gear lying about.
Thanks,
Scott W.
N-1521
Old November 27th 13, 03:57 AM posted to rec.aviation.soaring
Mike the Strike
On Tuesday, November 26, 2013 8:51:59 PM UTC-7, shkdriver wrote:
Hello,
Thanks,
Scott W.
N-1521
Hydraulic jacks have a fairly high failure rate. Screw jacks fail rarely and would be my first choice..
Working brakes would also be a nice feature!
Mike
Old November 27th 13, 05:04 AM posted to rec.aviation.soaring
JS
Hard to go wrong copying a Cobra. But leave the awful foam-backed carpet out.
Old November 27th 13, 06:06 AM posted to rec.aviation.soaring
Tony[_5_]
Set the height so you minimize dragging the tail of the trailer on the road when going in driveways. That is a constant problem with my driveway with most trailers.
I really liked the internal side storage compartments on Greg Cole's sparrowhawk trailer. He made the trailer as wide as the outside of the tires in the middle and tapered to "normal" width at the nose and tail. This created large storage areas ahead of and behind each wheel. That would require a major departure from Luebke plans though.
Keep good notes, someday I need a few more trailers. I have a set of Luebke 1-26 trailer plans for a future Cherokee II trailer.
Old November 27th 13, 04:24 AM posted to rec.aviation.soaring
Tim Taylor
I prefer screw down feet to using the tailgate. The tailgate hinge tends to wear with time from using it as a support.
Also if you are using the tailgate as the support you can't close the tailgate and have the trailer not at risk of turning while you are gone.
Get a nice set of screw jacks and you will be much happier in the long run.
Old November 27th 13, 06:11 AM posted to rec.aviation.soaring
Bob Kuykendall
On Tuesday, November 26, 2013 8:24:29 PM UTC-8, Tim Taylor wrote:
...The tailgate hinge tends to wear with time from
using it as a support...
Isn't that just another way of saying that most tailgate hinges are too flimsy?
Old November 27th 13, 11:19 PM posted to rec.aviation.soaring
Dan Marotta
I've got two of these on the back of my LAK T-4 trailer and love them:
http://www.pplmotorhomes.com/parts/r...iler-jacks.htm
Build in a storage box in front of the fuselage which occupies the full
width of the trailer at the front (under the spars) and is narrower further
aft to allow the wings to slide in. Make it go all the way back to the nose
cone of the glider.
"Tim Taylor" wrote in message
run.
Old November 27th 13, 06:14 AM posted to rec.aviation.soaring
son_of_flubber
I sorely miss the shock absorbers that the cheapskate designers of my 1999 Avionic trailer wrote off as decadent western luxury. The road vibration on the first long haul eased the pins out of the tailgate hinges. I don't imagine that that level of jarring vibration is good for a sailplane.
I've seen shock absorbers on some glider trailers.
I would also like some sturdy tie down points on the corners for tieing the trailer down when high winds are a possibility. Presently I loop the ropes around the frame members but that is a hassle to thread them through lying on my back in the wet grass.
Old November 27th 13, 11:20 PM posted to rec.aviation.soaring
Dan Marotta
Using the stabilizer jacks in back and the front wheel jack on the tongue of
the trailer, I don't tie mine down any more. It's weathered 60 mph winds at
Moriarty without moving.
"son_of_flubber" wrote in message
Old November 28th 13, 12:24 AM posted to rec.aviation.soaring
Dave Martin[_3_]
Don't think it has been mentioned.
A couple of good jacking points for the main wheel(s) and a
decent jack to raise the wheel(s).
The best towing trailer I have ever towed have had twin axle
with four wheels but they are awful to ground handle.
the tongue
of
mph winds
at
news:39bc5acd-5db0-40be-8bf9-
vibration
on
don't
sailplane.
for tieing the
the ropes
through lying
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
F.S. 3-glider trailer Nigel Pocock Soaring 0 September 29th 06 11:29 AM
glider trailer Q Ken Ward Soaring 10 August 28th 06 04:27 PM
glider trailer Q Steve Leonard Soaring 1 August 28th 06 05:29 AM
RSS feed for glider flying related news and features? Matthieu Soaring 0 November 16th 05 06:05 PM
