Air Extractor: Better than a Plastic Jesus?
Old December 15th 13, 06:01 PM posted to rec.aviation.soaring
Default Air Extractor: Better than a Plastic Jesus?
Noticing all the openings behind the cockpits of mainly Schleicher gliders such as -27 and 29's I'm asking myself if this is a real drag reducer or a placebo. For those unfamiliar: people have been cutting 4x2 openings into the fuselage about 8" behind the canopy cutout and put air vents - some with funnel-like contraptions on the inside of the turtle deck into their gliders. The funnel seems to suggest to the air molecules "this way out", some pilots may put arrow stickers on the inside so the air knows which way to flow. The whole thing is meant to avoid pressurizing the cockpit from the front air vent. Air leaking from the canopy seal would trip outside air flow to become turbulent.
Are there any serious comparison flights that were done following a scientific protocol to show the effect of such devices? Is this really better than putting a Tibetan prayer flag on the tail or a plastic Jesus on the glare shield? The latter can serve double purpose since I know where I would stick my transponder or PFlarm antenna...
Seriously, I'd be interested if anyone has found this thing useful beyond the statement that it must be good since all these hotshot pilots (insert call signs here) have one.
I'm waiting with jigsaw in hand for your responses, the LS8 rests uneasily in the basement!
Herb, J7
Old December 15th 13, 06:12 PM posted to rec.aviation.soaring
Brad[_2_]
I added one to my Tetra-15 when I built it. it was really my only solution to vent cockpit air since the tailboom is sealed off aft of the wing T.E.
no arrows to direct the outgoing air, but I can hear it rushing out the vent, so it must work. no hard data for the numbers guys, that being said the guys I fly with in their german glass seem to think the Tetra does just fine, even with a hole in the fuselage.
Brad
Old December 15th 13, 06:15 PM posted to rec.aviation.soaring
JS
Isn't it a bit cold to be discussing air vents?
Believe Guy has one in his LS8/18.
Uncle Hank might know something about this.
Perhaps ask Dick Butler or the Jonker brothers.
If you have paid "LS tax", try DG.
They really suck. The extractor, of course.
Old December 15th 13, 09:28 PM posted to rec.aviation.soaring
waremark
The JS1 fuselage looks to me identical to the ASH 26 but with extractor vents added. There might be a problem with having the vents - it would make me feel guilty about putting the stuff I like to take with me on the luggage deck. Look forward to hearing whether anyone knows whether they really make a difference.
Old December 17th 13, 03:32 PM posted to rec.aviation.soaring
BruceGreeff
Indeed the external shape of the JS1 fuselage is a direct (and
apparently authorised) copy of the ASW26. The brothers started modifying
one that needed two new wings.
Internally it is somewhat different.
The "mould" is still gracing our skies and was for sale last I saw...
Bruce
Bruce Greeff
T59D #1771
Old December 17th 13, 03:41 PM posted to rec.aviation.soaring
Tom K (TK)
http://www.ebay.com/itm/like/150944329699?lpid=82
The plastic Jesus might be cheaper, and it might help with a prayer for a divine thermal!
Old December 15th 13, 11:51 PM posted to rec.aviation.soaring
On Sunday, December 15, 2013 1:01:20 PM UTC-5, wrote:
Noticing all the openings behind the cockpits of mainly Schleicher gliders such as -27 and 29's I'm asking myself if this is a real drag reducer or a placebo. For those unfamiliar: people have been cutting 4x2 openings into the fuselage about 8" behind the canopy cutout and put air vents - some with funnel-like contraptions on the inside of the turtle deck into their gliders. The funnel seems to suggest to the air molecules "this way out", some pilots may put arrow stickers on the inside so the air knows which way to flow. The whole thing is meant to avoid pressurizing the cockpit from the front air vent. Air leaking from the canopy seal would trip outside air flow to become turbulent. Are there any serious comparison flights that were done following a scientific protocol to show the effect of such devices? Is this really better than putting a Tibetan prayer flag on the tail or a plastic Jesus on the glare shield? The latter can serve double purpose since I know where I would stick my transponder or PFlarm antenna... Seriously, I'd be interested if anyone has found this thing useful beyond the statement that it must be good since all these hotshot pilots (insert call signs here) have one. I'm waiting with jigsaw in hand for your responses, the LS8 rests uneasily in the basement! Herb, J7
Ask Erik Mann his opinion. He has one in his LS-8.
UH
Old December 16th 13, 11:32 AM posted to rec.aviation.soaring
UH
I'm going for the vent installation this winter - already have the PJ ... kk
Old December 16th 13, 06:17 PM posted to rec.aviation.soaring
Papa3[_2_]
Not quite the direct answer you're looking for, but you do know that DG seems to think that venting cockpit air matters, right?
http://www.dg-flugzeugbau.de/index.p...dl-absaugung-e
On the theory that the Nixon Air Extractor had a better chance of working than the Plastic Jesus, I installed one two winters ago. Obvious improvement in cockpit airflow and decrease in canopy noise at high speed suggest it's doing "something". I built a little foam block with a string attached and plan to do some testing on cockpit pressure at speed with/without the exit orifice available. Expect to be able to show increased cockpit pressure with my handy-dandy NK Kestrel Wx meter and also see if there is measurable outflow by locating the Kestrel in the exit area. All that proves is a first-order measurement (i.e. something is happening due to the vent). In terms of performance measurement, maybe faith (along with the Plastic Jesus) is justification enough?
P3
UH
Old December 16th 13, 07:23 PM posted to rec.aviation.soaring
Craig Funston[_2_]
P3
UH
If Dick Butler believes in it, that's good enough for me :-)
Craig
Plastic Bonding Urban^nja Restoration 2 September 9th 11 03:57 AM
337 for interior plastic Robert M. Gary Owning 26 November 28th 05 04:24 PM
Repairing Plastic Jay Honeck Owning 5 February 2nd 04 09:20 PM
New Plastic Certificates... Ekim Piloting 3 November 28th 03 08:51 PM
Plastic fender? Steve Thomas Home Built 0 August 28th 03 04:36 PM
