337 for interior plastic
Old November 15th 05, 09:11 PM posted to rec.aviation.owning
Default 337 for interior plastic
So, I sent off for new interior plastic. The pieces are not PMA'd so
the dealer is telling me I need to do a 337. Reading part 43 I see
preventative maint says..
(9) Refinishing decorative coating of fuselage, balloon baskets,
wings tail^
M
group surfaces (excluding balanced control surfaces), fairings,
cowlings,^M
landing gear, cabin, or cockpit interior when removal or disassembly
of any^M
primary structure or operating system is not required.^M
This makes me think I can replace my cabin vent covers myself. Does
that means I can also sign the 337? Do I need to pay an A&P a minimum 1
hour labor to sign the 337?
-Robert
Old November 15th 05, 10:43 PM posted to rec.aviation.owning
The dealer is nuts. What part 43 is telling you, is that you do NOT need a
337, in fact the FSDO inspector will deny your 337 because it is not a major
repair or alteration. All you need to do is install it and make a log book
entry under your name and cert #.
wings tail^
M
cowlings,^M
of any^M
-Robert
Old November 16th 05, 03:50 AM posted to rec.aviation.owning
Certainly what I would do. However, in addition to name and cert # you
need to include date, type of "Cert," and reference the maintenance
manual pages installation of the interior items.
Correct. My omission.
Old November 16th 05, 04:16 AM posted to rec.aviation.owning
Part 43 tells you that replacing these items is preventative maintenance, *not*
a major repair or alteration. No 337 is required.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
Old November 16th 05, 08:04 AM posted to rec.aviation.owning
C'mon folks. This clown has been in these ngs for a month now railing on
these plastic parts. He is either trolling or paranoid.
In either case, let him deal with it himself or pay a thousand dollars to
one of my colleagues for a logbook signature.
(BTW, I'm available for the logbook signature if he is {;-) )
Old November 16th 05, 11:32 PM posted to rec.aviation.owning
Of course when I posted the first time I was asking about needing a 337
because it is not PMA'd. This post was asking if a 337 was necessary if
I could sign it since the work itself seems to fall under preventative
maintenance.
Old November 17th 05, 04:04 AM posted to rec.aviation.owning
Again, you are a troll or paranoid. Pick one and tell us which it is.
maintenance.
Old November 17th 05, 06:30 AM posted to rec.aviation.owning
I know what I am, sounds like you need to pick.
I'm asking if there is a reasonable way to replace my vent covers with
full FAA approval. If you aren't interested in aviation, FAA
regulations or the maintenance of aircraft, I suggest you find another
newsgroup to read.Meanwhile, let the rest of us enjoy our aircraft and
do our best to keep the FAA happy.
-Robert
Old November 17th 05, 06:42 AM posted to rec.aviation.owning
Robert, advice given here is worth exactly what you pay for it...
Information from reading between the lines of what Jim Weir types...
Priceless...
Old November 17th 05, 12:33 PM posted to rec.aviation.owning
Well specifically, it requires a description of the work. There's
no requirement to reference maintenance manual pages.
22 Nov. 2005, Ronald Natalie, Replaced decorative interior plastics
with kit from PlanePlastics, Inc. SIGNATURE NNN-NN-NNNN Private
Pilot.
