I am helping a friend put new tires on a 2002(?) Cobra trailer.
The original tires are 14" Cooper 185R14C mud and snow. They seem to be really hard to come by for an exact replacement. Anyone know of other good options? Thanks in advance. |
On Thursday, January 30, 2014 2:18:24 PM UTC-5, MNLou wrote:
I am helping a friend put new tires on a 2002(?) Cobra trailer. The original tires are 14" Cooper 185R14C mud and snow. They seem to be really hard to come by for an exact replacement. Anyone know of other good options? Thanks in advance. You haven't said the gross weight, nor the driving speed required. Trailer tires are preferred and I don't know why "mud and snow" would be needed (I try not to drive the trailer in snow!). For my heavy (1100kg) trailer and warp-mode, I just installed: Kumho radial trailer tire model 875 product#1575013 185R14C, Ply Rating/Load Range 8/D, max load 1874lbs @ 65psi Rim STD (inch) 5.00, Rim APP (inch) 6.00, Overall Dia (inch) 25.6, Section Width (inch) 7.4, Static Load Radius 11.9 Third set of tires on this trailer! Hope that helps, Best Regards, Dave "YO electric" |
On Thursday, January 30, 2014 4:13:18 PM UTC-5, Dave Nadler wrote:
On Thursday, January 30, 2014 2:18:24 PM UTC-5, MNLou wrote: I am helping a friend put new tires on a 2002(?) Cobra trailer. The original tires are 14" Cooper 185R14C mud and snow. They seem to be really hard to come by for an exact replacement. Anyone know of other good options? Thanks in advance. You haven't said the gross weight, nor the driving speed required. Trailer tires are preferred and I don't know why "mud and snow" would be needed (I try not to drive the trailer in snow!). For my heavy (1100kg) trailer and warp-mode, I just installed: Kumho radial trailer tire model 875 product#1575013 185R14C, Ply Rating/Load Range 8/D, max load 1874lbs @ 65psi Rim STD (inch) 5.00, Rim APP (inch) 6.00, Overall Dia (inch) 25.6, Section Width (inch) 7.4, Static Load Radius 11.9 Third set of tires on this trailer! Hope that helps, Best Regards, Dave "YO electric" Can you tell me if you got the tires locally? |
I had a similar question several years ago and used the following advice from ras. I have been very happy with these tires and plan to replace them with the same item soon. Tirerack will ship them to you for local mounting which saves a lot of running around looking and hassle.
John On Jul 22, 8:24 am, RN wrote: The tires on my Cobra trailer from the factory are marked 185R14C8PF (102/100N)LT They appear to be GT Radial Max Miler X Load Range D 1875 lb at 450KPA 65# cold Try tirerack.com - they have Kumho trailer tires that match what you have. I've used their semi trailer tires and found them to be acceptable, but I don't have any experience with the smaller ones. They list them for $ 80.00 each plus shipping. Ray Warshaw 1LK |
![]() I have been happy with Goodyear Marathon trailer tires. |
I upgraded my cobra with 15" tires and rims from tirerack.com
They were very helpful with determining bolt spacing and correct offset. Tires are lower profile and wider than original, trailer tows like it is on rails in all conditions. |
My local Discount Tire store found several stock tires that fit the original Cobra rims and recommended a trailer tire that has worked well for me. Here in Arizona, tires rot in the sun before the tread wears and have to be changed every few years.
Mike |
2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 02:42 PM |
New Cobra Trailer Tires | Randy[_2_] | Soaring | 5 | September 23rd 10 03:58 AM |
Trailer tires for old (1981) Komet Trailer | [email protected] | Soaring | 3 | May 13th 09 10:24 PM |
Cobra Trailer Tires (US) | RN | Soaring | 25 | July 25th 08 06:11 AM |
Replacing Cobra trailer 13 inch tires with larger? | Andy Blackburn | Soaring | 6 | August 19th 04 03:15 AM |
