Transponder causing problems for Airlines on final ????
Old June 14th 04, 04:32 AM
Ray Bengen
Default Transponder causing problems for Airlines on final ????
There he was, holding for takeoff, ready to go, transponder alive, and he
gets bitched at by the tower for "causing problems with the airliner's nav
on final, switch transponder to standby."
Makes sense to anyone ???
Ray
Old June 14th 04, 04:40 AM
Steven P. McNicoll
"Ray Bengen" wrote in message
news
Sounds like TCAS
Old June 14th 04, 05:36 AM
BTIZ
I agree.. sounds like the aircrafts on final's TCAS lit off when it picked
up the transponder of the aircraft waiting to depart.. sitting right next to
the runway..
BT
nk.net...
news
he
nav
Sounds like TCAS
Old June 14th 04, 05:54 AM
PS2727
I think the tower was a bit harsh then because at several large airports ALL
aircraft are asked to keep the transponder on during ground operation all the
way to/from the gate. TCAS systems have a mode which gets rid of most unwanted
warnings for takeoffs and landings. There is nothing at all wrong with turning
the transponder on when approaching #1 for takeoff, it's better than forgetting
to turn it on at all. If it is an ongoing problem at that airport try calling
the folks in the tower to find out why and how they would like transponders
handled on their field.
Old June 14th 04, 01:10 PM
OtisWinslow
I was taught the old "Lights, Camera, Action" thingy when crossing the
hold line onto the runway for takeoff.
"PS2727" wrote in message
ALL
unwanted
turning
forgetting
calling
transponders
Old June 14th 04, 03:25 PM
EDR
In article et,
Sounds like TCAS
TCAS only works with Mode-S transponders.
Old June 14th 04, 03:30 PM
Tom Sixkiller
"EDR" wrote in message
In article et,
he
nav
Sounds like TCAS
Why wouldn't that be the case here?
Old June 14th 04, 03:31 PM
Steven P. McNicoll
Negative.
Old June 14th 04, 04:07 PM
Garner Miller
In article , EDR
Sounds like TCAS
Who told you that? A Mode C transponder looks the same on a TCAS
screen as Mode S. The only difference is that two Mode-S-equipped
airplanes are able to coordinate a TCAS maneuver (so both airplanes
won't get told "climb" and climb into each other).
TCAS will interact and with Mode C transponders just fine, and will
even show and give a traffic advisory for aircraft with no altitude
encoding at all.
Garner R. Miller
ATP/CFII/MEI
Manchester, CT =USA=
Old June 14th 04, 05:43 PM
EDR
In article , Garner Miller
In article , EDR
Sounds like TCAS
encoding at all.
Okay, TCAS I vice TCAS II. Everyone should specify.
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
