Transponder test after static system opened?
Old March 10th 04, 03:19 AM
Jack I
Default Transponder test after static system opened?
Hi all,
So are you required to get a transponder test any time the static
system has been opened (for VFR flight)?
You are required to get a static/altimeter/xpdr test for IFR flight
any time the static system has been opened (91.411).
91.413 refers to maintenance on the transponder (and presumably
encoder) but has no reference to the static system.
My IA wants me to get a transponder test because he had some of the
static hoses off. I'd prefer to wait until I get some radio work
done in a month or so.
Jack
91.413 ATC transponder tests and inspections.
(a) No persons may use an ATC transponder that is specified in 91.215(a),
121.345(c), or §135.143(c) of this chapter unless, within the preceding 24
calendar months, the ATC transponder has been tested and inspected and
found to comply with appendix F of part 43 of this chapter; and
(b) Following any installation or maintenance on an ATC transponder where
data correspondence error could be introduced, the integrated system has
been tested, inspected, and found to comply with paragraph (c), appendix E,
of part 43 of this chapter.
Transponder Landing System ??? Trent D. Sanders Instrument Flight Rules 23 September 19th 04 08:59 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
IFR - VFR Static and Transponder Inspections (dallas, tx) Dave Aviation Marketplace 3 September 5th 03 02:05 AM
IFR - VFR Static and Transponder Inspections (dallas, tx) Dave Owning 3 September 5th 03 02:05 AM
