Operation without a transponder
Old September 13th 04, 06:24 PM
flyer
Default Operation without a transponder
I need to get a biannual transponder check. I would like to do it
October 1st instead of sometime near the end of September to get an
"extra" month the next time around. The FARs say that I can operate
without a transponder in the airspace where a Mode C transponder is
normally required by requesting an ATC deviation. I would fly the
aircraft with the transponder off, VFR, from Torrance, CA airport to
Hawthorne, CA airport, about 4 miles away where the pitot static and
transponder check is to be made. The pitot static test is not a
problem as it is only required to be current if the aircraft is to be
flown under IFR.
The FAR text regarding flight without an "operable" transponder is:
(d) ATC authorized deviations. Requests for ATC authorized
deviations
must be made to the ATC facility having jurisdiction over the
concerned
airspace within the time periods specified as follows:
(1) For operation of an aircraft with an operating transponder but
without
operating automatic pressure altitude reporting equipment having a
Mode C
capability, the request may be made at any time.
(2) For operation of an aircraft with an inoperative transponder
to the
airport of ultimate destination, including any intermediate stops,
or to
proceed to a place where suitable repairs can be made or both, the
request
I would be requesting under (d) (2). It I take off from Torrance
Airport that is Class C airspace, I guess that would be the immediate
ATC jusrisdiction. But I am also under the Class B airspace of LAX
where a transponder is also required. It it sufficient to get an O.K.
from Torrance tower?
Old September 13th 04, 06:50 PM
zatatime
flown under IFR.
deviations
concerned
without
Mode C
to the
or to
request
If you're really concerned with adhering to the letter of the law when
out of inspection for just one day, I'd call my local FSDO and get a
ferry permit. Then you can use the transponder during the flight, not
need a waiver, and be ok.
HTH.
z
Old September 13th 04, 09:51 PM
Peter Duniho
"Bob Moore" wrote in message
. 172...
Nope! You need a "24 month" transponder check.
Biannual means twice-a-year.
You need to get off that horse; it's a little too high. "Biannual" means
both twice a year, and biennial.
Old September 13th 04, 10:15 PM
rv9er
biannual or biennial
A biannual event happens twice a year: We make a biannual visit to the
in-laws: once at Christmas and again in the summer. A biennial event happens
every two years: The school was due for its biennial inspection. (A biennial
plant lasts two years.)
Transponder test after static system opened? Jack I Owning 6 March 14th 04 04:09 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 01:18 AM
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons Curtl33 General Aviation 7 January 10th 04 12:35 AM
transponder codes Guy Elden Jr. Piloting 1 December 2nd 03 06:21 PM
transponder check? Russell Duffy Home Built 10 August 15th 03 12:36 AM
