Ross Reduction Unit - Prop hub removal???
Old March 24th 04, 03:04 AM
R&R Sherwood
Default Ross Reduction Unit - Prop hub removal???
The front seal of my Ross Aero Reduction unit needs replacing but I can't
remove the prop hub pin. The darn thing won't budge...even under a 4000
lb.hydraulic press. Has anyone had experience removing the prop hub?
Warning.... After removing the reduction from my engine I found two set
screws that hold the planetary gear shafts in place had backed off. This
allowed the gear shafts to move out of position, had this situation gone
unchecked I could have had a catastrophic failure. If you own a Ross unit
I would suggest that the set screws be checked.
Russell Sherwood
Houston, TX
Old March 24th 04, 08:06 PM
Corky Scott
On Wed, 24 Mar 2004 03:04:43 GMT, "R&R Sherwood"
Russell Sherwood
Houston, TX
You might want to give a call to Tracy Crook who used a Ross reduction
box and then designed his own based loosely on it.
Corky Scott
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
Ross 2.85 reduction drive Peter C Home Built 0 August 26th 03 03:55 PM
