Metal Prop vs. Wood Prop
Old September 21st 03, 01:21 AM
Larry Smith
Default Metal Prop vs. Wood Prop
I have a wood prop on my Taylorcraft and the GPS says it's slow, at around
65 kts. How about a discussion on the relative merits of wood and aluminum
props. I understand that wood is easier on your engine but the aluminum
prop is more efficient. Another thing I notice too, especially on the
O-320 and O-360-powered RV's is that the wood prop is so light it has little
flywheel effect and if you don't have your timing retarded, it will kick
back in a heartbeat. I figure the wood prop on a Van's aircraft is for CG.
I think what I'll do is buy an aluminum prop and try it for a while. I
couldn't keep up with a DCO-75 last week and it was a little embarrassing,
since his engine was sick. But he had an aluminum prop.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
Direction of warping wood? BllFs6 Home Built 2 September 1st 03 11:52 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
