As is common in the industry, our electric utility performs regularly
scheduled air patrols. Our aerial contractors are looking for so called "danger trees" that could come in contact with the lines, right of way encroachments, and facility maintenance items. We're using both fixed wing and rotary aircraft. It is a challenge to train contractors and it's labor intensive to investigate each problem. We think a better way of performing this task is to have the contractor provide a digital still image of each item in his report along with the associated geographic coordinate (accuracy is not an issue since anything within 500' is acceptable). I would appreciate any insight, experiences, or comments relative to this topic. Thanks, Mark |
task is to have the contractor provide a digital still image of each item in his report along with the associated geographic coordinate Just curious as to why you specify digital. I've been using flexible chemical imaging ribbon for a very long time, and it has many advantages over digital. The key thing is the photograph, not the medium, unless I'm missing something that can be done only if the image is originated digitally. Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
Jose wrote:
We think a better way of performing this task is to have the contractor provide a digital still image of each item in his report along with the associated geographic coordinate Just curious as to why you specify digital. I've been using flexible chemical imaging ribbon for a very long time, and it has many advantages over digital. The key thing is the photograph, not the medium, unless I'm missing something that can be done only if the image is originated digitally. Jose The digital image may be stored in a database for later retrieval. Also, analog photography is on its way out. Major labs across the country (USA, for you international readers) are shutting down their film processing operations and going totally digital. Cheers, Jim |
In article .com,
wrote: We think a better way of performing this task is to have the contractor provide a digital still image of each item in his report along with the associated geographic coordinate (accuracy is not an issue since anything within 500' is acceptable). Almost all digital cameras will timestamp their images. Almost all handheld GPSs can produce timestamped tracklogs of where they go. As long as the camera's time is set to the GPS time at the beginning of the day, and suitable track log settings are chosen, you can just use them independently and work out later where you were at the moment a photo was taken. I would recomment a relatively high resolution camera without a long lens. That way the picture will contain a lot of context information to pinpoint the location, but enough information at the center to zoom in and see the problem. -- Ben Jackson http://www.ben.com/ |
Thanks to all for the good advice.
I'm somewhat surprised that there is so little information on the web relative to aircraft camera mounts and remote camera controls. It seems as if the industry is set up strictly for higher altitude acquisition. Incidentally, our fixed wing contractor does employ a trained spotter (his wife). We know this camera idea will be beneficial but finding the hardware is going to be the biggest challenge. If anyone has any experience, knowledge, or insight on equipping the aircraft, please share it. Mark |
oups.com... Thanks to all for the good advice. I'm somewhat surprised that there is so little information on the web relative to aircraft camera mounts and remote camera controls. It seems as if the industry is set up strictly for higher altitude acquisition. Incidentally, our fixed wing contractor does employ a trained spotter (his wife). We know this camera idea will be beneficial but finding the hardware is going to be the biggest challenge. If anyone has any experience, knowledge, or insight on equipping the aircraft, please share it. Mark Mark, http://www.tylermount.com/frameshome.html May be overkill for your needs. You might only need to consider some gyro stabilization for either the camera or that will go on the lens like: http://www.ken-lab.com/html/rafferty_1.html Hope some of this is helpful. Jay Beckman PP-ASEL Chandler, AZ |
![]() "Ben Jackson" wrote in message news:laIvd.655125$mD.454233@attbi_s02... In article .com, wrote: We think a better way of performing this task is to have the contractor provide a digital still image of each item in his report along with the associated geographic coordinate (accuracy is not an issue since anything within 500' is acceptable). Almost all digital cameras will timestamp their images. Almost all handheld GPSs can produce timestamped tracklogs of where they go. Some of the better digital SLRs will accept GPS stamping. |
"C J Campbell" wrote in message
... Some of the better digital SLRs will accept GPS stamping. Do you know any specific brand/models? That would be very useful information, both here and generally. I wasn't aware of any with that functionality built in, but would love to know which ones do. |
Home aerial for an ICOM AC-A5? | jls | Home Built | 14 | December 14th 04 07:19 PM |
Aerial PHotography Flights 'Required' to File Flight Plans | C J Campbell | Piloting | 15 | December 6th 04 02:17 PM |
Different Aerial Imagery/Patrol jobs? | TooPlaneCrazy7 | Piloting | 19 | July 16th 04 12:43 AM |
FS: 1990 "Aerial Firepower" Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | July 11th 04 07:50 AM |
FS: 1990 "Aerial Firepower" Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | May 25th 04 05:10 AM |
