Home aerial for an ICOM AC-A5?
Old December 10th 04, 05:13 PM
jls
Default Home aerial for an ICOM AC-A5?
"Avery Wagg" wrote in message
Hi folks,
I will often use my handheld ICOM IC-A5 transceiver as an ordinary
aviation
band scanner at home. However, the the small aerial on the unit doesn't do
too much food whilst I sit in the basement. I'd like to build an outside
aerial for it that is more effective.
Does anyone have any tips on making up a home aeraial for an IC-A5 that I
could implement. I do have an old TV aerial out back (with a 75 ohm cable
attached).
..Avery Wagg
Give Jim Weir time to reply; I believe he sells a kit for an outside
aerial.
Best Home Base Work Reynard Home Built 0 November 9th 04 05:37 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 03:55 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 12:52 PM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 01:39 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Home Built 0 January 23rd 04 03:43 AM
