Stones x Cubits = Moment?
I just couldn't resist... ;-) Congrats on the ticket. Bart Anne-Marie Maddison wrote: Finally re'c my ppl h license from the CAA , had to wait over 3 weeks for them to process it - that was a long 3 weeks as i wanted to go flying with friends..Anyway , took my first passenger out who works at the flight school - studying for his CPL - wanted an experienced first passenger to see what it was like . This guy is light in weight and fflight was fine.... Took another friend to the School on Friday for a fly , we were going out in my Robinson r 22 beta 2 . I'm doing my pre-flights and was shocked to find we were out of balance . I'm 14 stone and my pal is 16 stone . It worked out that we could poss get around half gallon of fuel approx 3lbs on board ,not even enough to deal with start up and shut down . Whilst i understand weight is an issue ,i was amazed to see this . My instructor is very light - 150lbs and my passenger was 224lbs.I have many large framed friends who i have told i will take for a jolly , now i've got to ask them to lose a few pounds before we can fly.. We ended up changing to an older machine that has the 320 engine that is lighter and managed to go for a short flight,still being restricted to a light fuel load .My friend enjoyed the flight immensly . Having it basically thrust in my face like that, I have learned a valuable lesson early on about weight and balance........ cheers Ben |
![]() that we could poss get around half gallon of fuel approx 3lbs on board ,not even enough to deal with start up and shut down . Whilst i understand weight is an issue ,i was amazed to see this . My instructor is very light - 150lbs and my passenger was 224lbs.I have many large framed friends who i have told i will take for a jolly , now i've got to ask them to lose a few pounds before we can fly.. Surely the problem is weight rather than balance -- as the fuel is behind the mast you'd be better to have more rather than less fuel to move the CG backwards unless weight was the issue. I remember my problem was compounded with aft cyclic movement issues due to my beer gut :-) We ended up changing to an older machine that has the 320 engine that is lighter and managed to go for a short flight,still being restricted to a light fuel load . Strange -- I had always thought the HP had the battery in the front (or was that just the Mariner)? I seem to remember HPs "kneel down" more on lifting than the later Beta 2. Solution? Type conversion to an R44.... Regards Andrew (who learned to fly at 240lbs with a 170 lb tutor and not much more than a prayer in the tank :-) -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
Could you actually run out of cyclic before running out of fuel and if you
ever got into that situation would a safe or survivable landing be possible. e.g running landing or ditching. Mike Williams (non pilot) "Andrew Crane" wrote in message ... that we could poss get around half gallon of fuel approx 3lbs on board ,not even enough to deal with start up and shut down . Whilst i understand weight is an issue ,i was amazed to see this . My instructor is very light - 150lbs and my passenger was 224lbs.I have many large framed friends who i have told i will take for a jolly , now i've got to ask them to lose a few pounds before we can fly.. Surely the problem is weight rather than balance -- as the fuel is behind the mast you'd be better to have more rather than less fuel to move the CG backwards unless weight was the issue. I remember my problem was compounded with aft cyclic movement issues due to my beer gut :-) We ended up changing to an older machine that has the 320 engine that is lighter and managed to go for a short flight,still being restricted to a light fuel load . Strange -- I had always thought the HP had the battery in the front (or was that just the Mariner)? I seem to remember HPs "kneel down" more on lifting than the later Beta 2. Solution? Type conversion to an R44.... Regards Andrew (who learned to fly at 240lbs with a 170 lb tutor and not much more than a prayer in the tank :-) -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
Mike
the way i understand it is ( not an expert though ) ,if the heli isn't in balance to manufacturers recomendations then you can run out of cyclic.That is the way i have had it explained to me . You would run out of cyclic straight away because you are out of balance. cheers Ben "Mike Williams" wrote in message ... Could you actually run out of cyclic before running out of fuel and if you ever got into that situation would a safe or survivable landing be possible. e.g running landing or ditching. Mike Williams (non pilot) "Andrew Crane" wrote in message ... that we could poss get around half gallon of fuel approx 3lbs on board ,not even enough to deal with start up and shut down . Whilst i understand weight is an issue ,i was amazed to see this . My instructor is very light - 150lbs and my passenger was 224lbs.I have many large framed friends who i have told i will take for a jolly , now i've got to ask them to lose a few pounds before we can fly.. Surely the problem is weight rather than balance -- as the fuel is behind the mast you'd be better to have more rather than less fuel to move the CG backwards unless weight was the issue. I remember my problem was compounded with aft cyclic movement issues due to my beer gut :-) We ended up changing to an older machine that has the 320 engine that is lighter and managed to go for a short flight,still being restricted to a light fuel load . Strange -- I had always thought the HP had the battery in the front (or was that just the Mariner)? I seem to remember HPs "kneel down" more on lifting than the later Beta 2. Solution? Type conversion to an R44.... Regards Andrew (who learned to fly at 240lbs with a 170 lb tutor and not much more than a prayer in the tank :-) -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
![]() "Mike Williams" wrote in message ... Could you actually run out of cyclic before running out of fuel and if you ever got into that situation would a safe or survivable landing be possible. e.g running landing or ditching. Breathe in :-) The nice thing about the Robinsons is you have the option to raise the cyclic up to your chin to get the extra stick travel required. Your limitations with the weight too far forward a - reduced aft stick movement available - reduced clearance between tailboom and rotors - reduced flap/mast clearance The worst thing is if you're going cross country with lots of people/weight and full tanks. As you burn the petrol off, you're unaware of the change in balance because you have a fair amount of forward stick to maintain cruise speed. It's only when you get to the destination you realise things are becoming uncomfortable. If weight and balance are going to be an issue, calculate them with both full and empty fuel before getting airborne, Regards Andrew -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
So, if on a flight distance of say 200 miles and with a passenger, would we
need to refuel several times just to maintain CG. Sorry about the questions, but remember I'm not a pilot but eager to learn all I can for the future. Mike W. "Andrew Crane" wrote in message ... "Mike Williams" wrote in message ... Could you actually run out of cyclic before running out of fuel and if you ever got into that situation would a safe or survivable landing be possible. e.g running landing or ditching. Breathe in :-) The nice thing about the Robinsons is you have the option to raise the cyclic up to your chin to get the extra stick travel required. Your limitations with the weight too far forward a - reduced aft stick movement available - reduced clearance between tailboom and rotors - reduced flap/mast clearance The worst thing is if you're going cross country with lots of people/weight and full tanks. As you burn the petrol off, you're unaware of the change in balance because you have a fair amount of forward stick to maintain cruise speed. It's only when you get to the destination you realise things are becoming uncomfortable. If weight and balance are going to be an issue, calculate them with both full and empty fuel before getting airborne, Regards Andrew -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
The weight and balance computer programme at the flight school i use
calculates it all for you . Basically you put in weights of pilot / passenger , fuel and any baggage (this is for a R22 ).The fuel amount can be to max take off weight -what weight is left between the max take off weight and the weight of the heli ,people and baggage.This programme then gives you weight and balance at take off and at landing with 5 gallons left on board ..you should always try and land with approx 5 gallons incase a divert is called at any time . So,your take off and landing weight and balance is callculated for you. Now i am going to aasume the following ,if your weight and balance is ok for take-off and landing then i would presume you do not check in flight because you are checking the 2 extreme parameters and these are ok. In the case of me and my heavy friend we were out of balance on take-off and out on balance on arriving with 5 gallons om board calculated.thats why we switch machine and went for a short flight. Cheers Ben "Mike Williams" wrote in message ... So, if on a flight distance of say 200 miles and with a passenger, would we need to refuel several times just to maintain CG. Sorry about the questions, but remember I'm not a pilot but eager to learn all I can for the future. Mike W. "Andrew Crane" wrote in message ... "Mike Williams" wrote in message ... Could you actually run out of cyclic before running out of fuel and if you ever got into that situation would a safe or survivable landing be possible. e.g running landing or ditching. Breathe in :-) The nice thing about the Robinsons is you have the option to raise the cyclic up to your chin to get the extra stick travel required. Your limitations with the weight too far forward a - reduced aft stick movement available - reduced clearance between tailboom and rotors - reduced flap/mast clearance The worst thing is if you're going cross country with lots of people/weight and full tanks. As you burn the petrol off, you're unaware of the change in balance because you have a fair amount of forward stick to maintain cruise speed. It's only when you get to the destination you realise things are becoming uncomfortable. If weight and balance are going to be an issue, calculate them with both full and empty fuel before getting airborne, Regards Andrew -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
Weight and Balance Formula, Can one calculate the envelope | Joe Wasik | Piloting | 12 | September 29th 04 08:15 AM |
172S Weight and Balance Question | David J | Piloting | 9 | March 23rd 04 01:08 AM |
Weight and Balance | JP | Piloting | 2 | January 13th 04 10:54 AM |
Weight & Balance Question | Harry Gordon | Piloting | 28 | December 30th 03 01:51 AM |
RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 04:08 AM |
