INFO:
Taking a 2 hour trip with two on board in 172S. We are 280 lb each.(560) Fuel 53 gal at (318lbs) a little luggage 50 to 75 pounds. 2002 172S Empty Weight (1720) after figuring W&B total weight is 2673 or 123 lbs over 2550 max takeoff and landing weight. Upon arrival I will be at or near landing weight after fuel burn. I can ask FBO to unload 20 gallons of fuel or so at an extra expense of $2.72 a gallon and get the numbers right. QUESTION: Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Please be nice to me I know I need to loose weight. I do want to be safe just don't have enough expierience to make this judgement call without a little help from the expierience in this group. David J PP-ASEL |
"David J" wrote in message
.. . [...] Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Sounds to me like your instructor should have done a better job instilling some basic judgment skills during your training. It is certainly not legal to take off over weight, nor to land over weight. As for whether it's safe, that depends. But if you don't have the experience to answer the question yourself, I'd say it's a sure bet it's not safe for YOU to do so. It's generally not safe for anyone, and the accident database is filled with pilots who misloaded their aircraft. As for the cost of unloading fuel, even if you did have to pay another $55, so what? That's small potatoes compared to the potential costs on not unloading fuel. But you shouldn't have to. Just inform the FBO in advance of your need, and they will simply refrain from topping off the tanks prior to your use of the airplane. If the FBO won't do this, you need to find an FBO that will; any respectable, safety-oriented FBO provides this service at no additional charge. Pete |
David J wrote: Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Overloading an aircraft increases the takeoff distance and reduces the rate of climb. That will reduce safety any way you look at it. Will the plane do it? Almost certainly. Can you do it legally? Nope. Personally, I would try to find a way to take the plane up for about 2.5 hours a day or so before this trip and fly the gas off. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
I'm also betting you'd find yourself without insurance if there was an
incident. "David J" wrote in message .. . INFO: Taking a 2 hour trip with two on board in 172S. We are 280 lb each.(560) Fuel 53 gal at (318lbs) a little luggage 50 to 75 pounds. 2002 172S Empty Weight (1720) after figuring W&B total weight is 2673 or 123 lbs over 2550 max takeoff and landing weight. Upon arrival I will be at or near landing weight after fuel burn. I can ask FBO to unload 20 gallons of fuel or so at an extra expense of $2.72 a gallon and get the numbers right. QUESTION: Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Please be nice to me I know I need to loose weight. I do want to be safe just don't have enough expierience to make this judgement call without a little help from the expierience in this group. David J PP-ASEL |
David,
I'm also betting you'd find yourself without insurance if there was an incident. And your basis for that statement? Aviation insurance policies no longer deny coverage for violation of FARs. They used to try to do so, but in virtually every accident someone can point out a violation, even it's only the "careless and reckless" catch-all, so that language was pulled out of the policies. All the best, Rick "David J" wrote in message .. . INFO: Taking a 2 hour trip with two on board in 172S. We are 280 lb each.(560) Fuel 53 gal at (318lbs) a little luggage 50 to 75 pounds. 2002 172S Empty Weight (1720) after figuring W&B total weight is 2673 or 123 lbs over 2550 max takeoff and landing weight. Upon arrival I will be at or near landing weight after fuel burn. I can ask FBO to unload 20 gallons of fuel or so at an extra expense of $2.72 a gallon and get the numbers right. QUESTION: Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Please be nice to me I know I need to loose weight. I do want to be safe just don't have enough expierience to make this judgement call without a little help from the expierience in this group. David J PP-ASEL |
"Rick Durden" wrote in message
m... I'm also betting you'd find yourself without insurance if there was an incident. And your basis for that statement? Aviation insurance policies no longer deny coverage for violation of FARs. They do? You should tell my insurance carrier that. Certain violations of the FARs DO invalidate my policy. Besides, an insurance policy need not have a general provision about FAR violations. It still would not be all that surprising to find a policy that stipulates that the plane be flown within its airworthiness certificate (including not being flown overweight). Nothing in the statement you're attempting to rebut said anything whatsoever about the policy having a general provision about FAR violations. When you've read every single insurance policy in existence, then you might feel free to make blanket generalizations like that. Until then, you might want to consider refraining from suggesting people can feel free to fly their aircraft overweight without worrying about being covered by their policy. Also, in the meantime, you might make a better effort to actually read statements you're trying to argue against. Pete |
Fuel 53 gal at (318lbs) a little luggage 50 to 75 pounds. 2002 172S Empty Weight (1720) after figuring W&B total weight is 2673 or 123 lbs over 2550 max takeoff and landing weight. David J PP-ASEL David, If the weight is an ongoing issue, I would get checked out in an aircraft capable of handling it. Have you looked into a C182? David (KORL) |
Thanks for all of the responses. The FBO did not have the equipment so I
bought a couple of cans from the old Walmart and we siphoned fuel out. It was to late to ask them not to top off tanks. Made the flight just fine I just wanted to know if there was a fudge factor built into the weight and balance and was not sure about the legal aspects. Thank You "David J" wrote in message .. . INFO: Taking a 2 hour trip with two on board in 172S. We are 280 lb each.(560) Fuel 53 gal at (318lbs) a little luggage 50 to 75 pounds. 2002 172S Empty Weight (1720) after figuring W&B total weight is 2673 or 123 lbs over 2550 max takeoff and landing weight. Upon arrival I will be at or near landing weight after fuel burn. I can ask FBO to unload 20 gallons of fuel or so at an extra expense of $2.72 a gallon and get the numbers right. QUESTION: Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Please be nice to me I know I need to loose weight. I do want to be safe just don't have enough expierience to make this judgement call without a little help from the expierience in this group. David J PP-ASEL |
The legally fly 10% over certified gross weight in Alaska...
-- Dan D. .. "David J" wrote in message . .. Thanks for all of the responses. The FBO did not have the equipment so I bought a couple of cans from the old Walmart and we siphoned fuel out. It was to late to ask them not to top off tanks. Made the flight just fine I just wanted to know if there was a fudge factor built into the weight and balance and was not sure about the legal aspects. Thank You "David J" wrote in message .. . INFO: Taking a 2 hour trip with two on board in 172S. We are 280 lb each.(560) Fuel 53 gal at (318lbs) a little luggage 50 to 75 pounds. 2002 172S Empty Weight (1720) after figuring W&B total weight is 2673 or 123 lbs over 2550 max takeoff and landing weight. Upon arrival I will be at or near landing weight after fuel burn. I can ask FBO to unload 20 gallons of fuel or so at an extra expense of $2.72 a gallon and get the numbers right. QUESTION: Can I safely/legally takeoff 4000 foot runway, 60 air temp elevation 400' 180hp or should I just bite the bullet and pay for the extra fuel to be unloaded as opposed to taking a chance. Please be nice to me I know I need to loose weight. I do want to be safe just don't have enough expierience to make this judgement call without a little help from the expierience in this group. David J PP-ASEL |
In article m,
"Blueskies" wrote: The legally fly 10% over certified gross weight in Alaska... Not exactly. Some 135 operators are allowed to go 15% over with specific approval blah, blah. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
| Thread Tools | |
| Display Modes | |
| Cessna 414! Weight & Balance | [email protected] | General Aviation | 3 | February 24th 05 11:33 PM |
| Weight and Balance | JP | Piloting | 2 | January 13th 04 11:54 AM |
| Weight & Balance Question | Harry Gordon | Piloting | 28 | December 30th 03 02:51 AM |
| RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 05:08 AM |
| Weight and balance question. | Wayne | Piloting | 5 | November 28th 03 07:45 PM |
