WX Block/WX Seal Question
Old March 10th 15, 05:51 PM posted to rec.aviation.soaring
vontresc
Default WX Block/WX Seal Question
So last year I buffed out my Libelle with 3M Finesse, and then waxed and sealed it with WX Block/Seal. Since spring has tentatively arrived here in the frozen tundra of the upper midwest, I started thinking about getting the old girl ready for the season.
So do I need to do any surface prep before reapplying the WX block other than washing off the winter grime and dirt? If not what do you suggest to do?
Thanks
Peter
Libelle N2045D S/N 13
Old March 10th 15, 07:43 PM posted to rec.aviation.soaring
Sean Franke
Thanks
Peter
If your finish is in great shape then no need for sanding out crazing or 3M polishing. You can start with Wx Seal & Block (after wiping clean with soap and water). Wx Seal is a cleaning-sealing compound which conditions the surface. Wx seal will clean residual dirt and wax then seals microscopic porosity.
Wx Block is the second step which can be applied on paint and gel coats. It has UV protection, anti-static properties and gel coat gloss.
Sean Franke
WX block and seal question Brad[_2_] Soaring 15 July 7th 17 02:35 PM
stab/elevator gap seal question Brad[_2_] Soaring 3 July 21st 11 12:48 AM
Block out someone? (Little Hitler) Jeff Military Aviation 6 April 13th 04 07:03 PM
Block Allocation? AES/newspost Piloting 23 February 12th 04 06:58 AM
More Info on Block 52 F-16 robert arndt Military Aviation 0 November 18th 03 03:07 PM
