stab/elevator gap seal question
Old July 20th 11, 10:53 PM posted to rec.aviation.soaring
Brad[_2_]
Default stab/elevator gap seal question
I've heard that on some sailplanes, putting a mylar gap seal on the
top surface can cause handling issues. Anyone care to comment on that?
I've added a mylar seal and the safety tape to the top of mine, and it
does indeed add a small step just ahead of the elevator, despite my
best attempts at hiding the fwd bump with safety tape.
Brad
Old July 20th 11, 11:06 PM posted to rec.aviation.soaring
Brad
The problem usually noted is when the safety tape or the seal comes
loose and acts like a spoiler, affecting elevator control.
It is unlikely, but not impossible for this to make the glider
uncontrollable.
Schleicher requires safety tape on elevator seals to avoid the problem
of seal lifting. Interestingly, they don't require it on flaps or
ailerons(this from '27 maint book).
That bump you have will likely act as a useful turbulator.
Commonly zig zag tape is put an inch or 2 ahead of the hinge line to
help retain flow attachment when deflected.
FWIW
UH
Old July 21st 11, 12:13 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Brad
The problem with adding mylar and transition tape is inadequate
adhesion between the wing & mylar and/or between the mylar and
transition tape. If I remember correctly, the guy that felt his Ventus
was uncontrollable near Uvalde had waxed his ship and then added the
transition tape over fresh wax. The tape lifted and believing the ship
was uncontrollable, he bailed out! I recommend the 10mm of the mylar
that will come into contact with the stab/wing/fin be sanded with 220
dry sandpaper and the coresponding 10mm area on the stab/wing/fin
also be sanded with 220 dry sandpaper. Wipe both surfaces with acetone
just before applying the mylar. Also, wipe the area where the
transition tape will go with acetone just before applying the tape.
Hope this helps,
JJ
Old July 21st 11, 12:48 AM posted to rec.aviation.soaring
Brad[_2_]
Brad
Hope this helps,
JJ
Thanks Hank and JJ,
My stab was recently waxed with the WX block and seal combo. The first
application of double sticky and safety tape pulled right off, just
like you said. I did a good acetone wipe and re-applied and now have
really good stick. For the wings maybe I will try that 220
grit........might be psychologically hard to do since I just spent a
bazillion hours sanding and re-painting and sanding and polishing the
wings!
Hey JJ................you wouldn't happen to have any LS type seat
backs in the corner of your shop would you? Or...........maybe I can
find one to use as a splash.
Brad
L-13 elevator aft bellcrank question Edward Kornfield Soaring 2 October 4th 10 10:31 PM
For Sale: 1-34 horizontal stab/elevator Mitch Deutsch Soaring 0 November 12th 06 03:46 PM
Unapproved Plastic Elevator Tips Question jls Owning 24 January 10th 05 03:09 AM
Elevator Turbulator tape question JJ Sinclair Soaring 39 October 17th 03 02:35 PM
Panel on C-130 vertical stab question B2431 Military Aviation 22 September 27th 03 07:47 PM
