Anyone have any experience connecting a power flarm to a dell streak via an ioio adaptor? Mine works for a while, then disconnects. Any help appreciated!
Hi,
I had a similar problem connecting to XCSoar on my Dell a few years ago. Despite loads of help from Max & Tobias at XCSoar I never really managed to resolve the issue. It might help if you upgrade to one of the later versions of Android available for the Dell on the net. In the end I changed from trying the IOIO wired connection to using a simple Bluetooth module available from eBay. Also needs level shifting using a Max3232 chip, again easily available on eBay Regards KN At 03:24 22 May 2015, Blake Seese 9V wrote: Anyone have any experience connecting a power flarm to a dell streak via an ioio adaptor? Mine works for a while, then disconnects. Any help appreciated! |
The highest version of Android I've found for the Streak is 2.3.7. There
might be higher available now, but mine works great with all functions so I don't see any need to upgrade further. On 5/22/2015 2:55 AM, Kevin Neave wrote: Hi, I had a similar problem connecting to XCSoar on my Dell a few years ago. Despite loads of help from Max & Tobias at XCSoar I never really managed to resolve the issue. It might help if you upgrade to one of the later versions of Android available for the Dell on the net. In the end I changed from trying the IOIO wired connection to using a simple Bluetooth module available from eBay. Also needs level shifting using a Max3232 chip, again easily available on eBay Regards KN At 03:24 22 May 2015, Blake Seese 9V wrote: Anyone have any experience connecting a power flarm to a dell streak via an ioio adaptor? Mine works for a while, then disconnects. Any help appreciated! -- Dan Marotta |
On Friday, May 22, 2015 at 11:02:00 AM UTC-6, Dan Marotta wrote:
The highest version of Android I've found for the Streak is 2.3.7.* There might be higher available now, but mine works great with all functions so I don't see any need to upgrade further. On 5/22/2015 2:55 AM, Kevin Neave wrote: Hi, I had a similar problem connecting to XCSoar on my Dell a few years ago. Despite loads of help from Max & Tobias at XCSoar I never really managed to resolve the issue. It might help if you upgrade to one of the later versions of Android available for the Dell on the net. In the end I changed from trying the IOIO wired connection to using a simple Bluetooth module available from eBay. Also needs level shifting using a Max3232 chip, again easily available on eBay Regards KN At 03:24 22 May 2015, Blake Seese 9V wrote: Anyone have any experience connecting a power flarm to a dell streak via an ioio adaptor? Mine works for a while, then disconnects. Any help appreciated! -- Dan Marotta Thanks Dan, How do I get the higher version if the streak is not on a cellular plan. It has wifi connectivity, can I download the 2.3.7 version somewhere? Thanks, Blake |
On Thursday, May 21, 2015 at 9:24:02 PM UTC-6, Blake Seese 9V wrote:
Anyone have any experience connecting a power flarm to a dell streak via an ioio adaptor? Mine works for a while, then disconnects. Any help appreciated! Dan, I ended up putting the butterfly back in for Flarm and going back to my Ipaq 3955 as it plugs into the Cambridge and runs XC Soar very well. The screen is harder to see, but I know it's a solid platform. At some point, I may buy an Oudie 2 and a K6 so I can have both info sets on one device. time will tell. I do have an Androport IOIO if anyone is interested in pursuing that route. Thanks for the help, Blake 3Y |
Mux, 302, Flarm Core, Dell Streak | Blake Seese 9V | Soaring | 5 | April 27th 15 03:06 PM |
ERIXX to Dell Streak via Bluetooth | [email protected] | Soaring | 2 | November 12th 14 10:01 PM |
Dell Streak - what ROM version? | [email protected] | Soaring | 7 | May 24th 14 05:09 PM |
Temperature Probe for Dell Streak | Dan Marotta | Soaring | 14 | April 20th 13 02:56 AM |
Dell Streak 5 available | soartech[_2_] | Soaring | 0 | November 14th 12 05:44 PM |
