Does anyone have experience with connecting an ERIXX flight logger with XC Soar via Bluetooth? I've got a Dell Streak running XC Soar 6.7.5 and an ERIXX flight logger that I would like to connect to one another for GPS position and pressure altitude. I've been looking at the NEMA Bluetooth module available at the following link. Has anyone done this successfully?
http://www.millenair.nl/shop/index.php? ... duct_id=91 |
Hi,
A K6Bt would work well for that. I have them in stock. http://www.cumulus-soaring.com/k6.htm#K6Bt I could also provide a Goddard cable for connecting the Erixx to the K6Bt and 12V power. The Erixx and K6Bt would both be powered by 12V. However, I should mention that the cost of the K6Bt ($200) and custom power/data cable ($75) are about 2/3 to 3/4 of the price of a new Oudie 2 Lite ($375) - which is supplied with a power/data cable which will connect directly to the Erixx. You can run XC Soar on the Oudie 2 Lite. For $625 you would get an Oudie 2 with a SeeYou Mobile Lifetime License. The Oudie 2 has been extremely popular. It is a great product. Best Regards, Paul Remde Cumulus Soaring, Inc. wrote in message ... Does anyone have experience with connecting an ERIXX flight logger with XC Soar via Bluetooth? I've got a Dell Streak running XC Soar 6.7.5 and an ERIXX flight logger that I would like to connect to one another for GPS position and pressure altitude. I've been looking at the NEMA Bluetooth module available at the following link. Has anyone done this successfully? http://www.millenair.nl/shop/index.php? ... duct_id=91 |
I use a K6Bt to connect my CAI-302 to my Dell Streak via bluetooth. It
was straight forward and easy to do. Or you could look into an IOIO device. Dan Marotta On 11/12/2014 9:45 AM, wrote: Does anyone have experience with connecting an ERIXX flight logger with XC Soar via Bluetooth? I've got a Dell Streak running XC Soar 6.7.5 and an ERIXX flight logger that I would like to connect to one another for GPS position and pressure altitude. I've been looking at the NEMA Bluetooth module available at the following link. Has anyone done this successfully? http://www.millenair.nl/shop/index.php? ... duct_id=91 |
Best way to connect US PowerFlarm to Dell Streak 5 | Blake Seese | Soaring | 1 | July 2nd 14 12:09 AM |
Dell Streak - what ROM version? | [email protected] | Soaring | 7 | May 24th 14 05:09 PM |
Temperature Probe for Dell Streak | Dan Marotta | Soaring | 14 | April 20th 13 02:56 AM |
Dell Streak 5 available | soartech[_2_] | Soaring | 0 | November 14th 12 05:44 PM |
Short review of the Dell Streak with XCSoar | Max Kellermann | Soaring | 6 | February 9th 11 04:22 PM |
