Electrical continuity of control linkages and electrical instruments
Old June 26th 15, 02:54 AM posted to rec.aviation.soaring
son_of_flubber
Default Electrical continuity of control linkages and electrical instruments
I had the seat pan out of my glider and I noticed that there are several braided wires connecting the metal stick to other metal parts and the (-) side of the power distribution block, battery, and (via power distribution wires) to the (-) of the electrical instruments (with small fuses on each instrument).
I understand that this has something to do with possible lightening strikes and also minimizing RF interference for radio, transponder etc..
Can someone provide a better explanation (or a link)?
If lightening hits a control rod, what happens to the pilot holding the hot stick?
Old June 26th 15, 02:56 AM posted to rec.aviation.soaring
son_of_flubber
I have a fiberglass glider with some steel structural members (no carbon fiber) ... if that matters.
Old June 26th 15, 05:04 AM posted to rec.aviation.soaring
2G
Electric current WILL find a current path thru the glider in the event of a lightning strike. YOU don't want to be a part of that current path. These braids ensure that the current will go thru the control rods, which are capable of carrying that current, and not thru the pilot's body, or other parts of the glider that might disintegrate.
Tom
Old June 26th 15, 07:36 AM posted to rec.aviation.soaring
Cookie
Corrosion control??? All dissimilar metals at same potential....
Cookie
Old June 26th 15, 12:22 PM posted to rec.aviation.soaring
Cookie
Cookie
Probably not so much for corrosion...but rather for static electric charge....all parts bonded to prevent sparks / arcs...to protect people and equipment.
Old June 26th 15, 12:47 PM posted to rec.aviation.soaring
Pat
This may be the link you need:
http://tinyurl.com/p7af5ww (accident report, pdf)
Old June 26th 15, 03:15 PM posted to rec.aviation.soaring
There's an explanation he https://www.faa.gov/regulations_poli...rame_handbook/
Vol 2, Chapter 11
Old June 26th 15, 04:09 PM posted to rec.aviation.soaring
Bob Kuykendall
On Thursday, June 25, 2015 at 6:54:02 PM UTC-7, son_of_flubber wrote:
...possible lightening strikes...
Nitpick:
* Lightning strikes with a flash of light
* Lightening strikes with a sawzall
Bob K.
Electrical questions AK Soaring 3 February 27th 08 02:39 AM
Gap Tape? Electrical OK? ContestID67 Soaring 10 May 2nd 06 07:37 AM
Electrical issue Jimmy B. Owning 8 March 2nd 05 12:11 AM
Electrical rewire Sam Fly Restoration 0 April 1st 04 03:11 AM
B-36 electrical system Q. John Mackesy Military Aviation 2 July 18th 03 05:41 AM
