Gap Tape? Electrical OK?
Old April 30th 06, 02:38 PM posted to rec.aviation.soaring
Default Gap Tape? Electrical OK?
I know that this is going to generate a long thread but --- what is so
great about $10/roll super thin, super flexible, super-wide gap tape?
I had it in my mind once that thin was the important part to prevent
seperation of the laminar flow or something equally distructive.
However a friend of mine made perfect sense when he said that this
would only affect performance if it was cross-ways to the air flow.
Obviously the wing root seal tape is not cross-ways.
Maybe the adhesive is distructive to the gell coat? If you left the
tape on all season I could see that this might be a factor but we
generally only leave it on for part of a day. 3M tape's adhesive is
good but not like duct tape or something.
Let's me know what you think.
- John
Old April 30th 06, 03:05 PM posted to rec.aviation.soaring
Any tape that doesn't come off is just fine. On a painted metal
sailplane, the adhesive is a bit more critical, but on gelcoat, it's
not as much an issue.
Some tapes have better adhesive, so the tape doesn't come loose under
temp changes and start to buzz - very annoying if it happens at the
beginning of a 6-10 hour flight.
Some adhesive leaves gunky residue. Some tapes split in cold weather.
Some sailplanes have some compound curves that require a good stretchy
tape.
There's some "religion" in picking the right tape
I like Mike Bowlus' "Maxi Tape". Not the cheapest around, but it
sticks wery well, stretches and goes around corners very well, and
doesn't leave nuch residue when removed.
-Tom
Old May 1st 06, 09:11 AM posted to rec.aviation.soaring
Even masking tape can be used - best take it off the same day, though.
Chris N.
10 rolls gap tape $20 postpaid in US TJ Soaring 0 April 29th 06 06:31 PM
60 Year Old Duct Tape Jay Honeck Piloting 11 January 15th 06 06:52 PM
Gap Tape TJ Soaring 0 October 22nd 05 04:18 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
