water ballast valve LS6c/LS7
Old August 11th 15, 08:23 AM posted to rec.aviation.soaring
Tibor Arpas
Default water ballast valve LS6c/LS7
Hi,
I'm struggling to elimitate water ballast leaks in a LS-7 after it has not been used for years. The wing valves seem to be one of the challenges. They leak regardless of the force applied to the actuator.
I assume the valves are the same as in LS6c (and not available as spare part any more)
Here is a picture of the valve https://goo.gl/photos/CvYt9SPy9efS8QR56
I couldn't find a way to dissasemble the valve to be able to inspect or replace the gasket. From one angle it's kind of possible to see into the valve, and it looks like it's just a metal ring pressing against plastic pipe with a tiny overlap. So no gasket?
Any idea how to fix the leak? Advice would be greatly appreciated, thanks!
Tibor
Old August 11th 15, 11:16 AM posted to rec.aviation.soaring
Vernon Brown
At 07:23 11 August 2015, Tibor Arpas wrote:
Hi,
not
They=
par=
t any more)
rep=
valve=
wi=
thanks!
Tibor
No it cant be disassembled, Its been chemically welded , it would have to
be cut open.
Old August 11th 15, 02:40 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Thick lube like vasalene libarely applied is the only answer I know. Believe the valve is like the LS-3a which uses a plastic ball on a stick. Goop lube on the ball as the rod is slowly turned. Do this before every flight where water is carried. May be able to reach the ball hith your finger, if not use a swab on a bent wire (coat hanger). Make sure the dump lever on the root rib (fuselage side) has a enough slop so that it isn't shoving on the rod before you want it to shove on the rod during dump.
Hope this helps,
JJ
Old August 11th 15, 07:07 PM posted to rec.aviation.soaring
Hope this helps,
JJ
I have no experience with LS valves but I can say that toilet wax (the ring that seals the tiolet to the floor) is way better than vasalene on S-H valves.
Old August 11th 15, 06:04 PM posted to rec.aviation.soaring
John Bojack J4
Does it leak outside the plane? I was going to suggest looking at the cable adjustments inside the fuselage. Perhaps the lever that activates the valve is poorly adjusted? J4
Old August 11th 15, 07:16 PM posted to rec.aviation.soaring
Tibor Arpas
Thanks for your suggestions. I was afraid there were no very good options. Yes, it also leaks when tested out of the glider.
Did anybody actually cut the valve open (and what did they do there?) or manufacture a replacement?
It's probably not the same system as LS3.
What do you guys think will happen if I let submerged in vinegar/water solution for an hour?
I have also Molykote 111 which is suposed to be better then vaseline, but I might investigate the wax solution more.
Tibor
On Tuesday, August 11, 2015 at 9:23:56 AM UTC+2, Tibor Arpas wrote:
Hi,
Tibor
Old August 13th 15, 02:39 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Mineral deposits in the valve seal may be causing the leak, you might try soaking the valve in Lime-a-Way or SLR, then flush out under pressure. Try to figure out a way to lube the seat when valve is inside the wing.
JJ
Old August 13th 15, 05:45 PM posted to rec.aviation.soaring
Papa3[_2_]
JJ
Yup. I would do everything possible to make sure the ball is able to seat correctly including cleaning as suggested, lubricating the O-Ring with glycerin first followed by wax to help it seat. I helped on two LS6 valve-jobs, and they were solved by the above. The mechanism itself is fairly simple, so the likely culprit is seating of the ball valve.
Erik Mann (P3)
DG-200 Water Valve S. Murry Soaring 12 August 24th 18 08:36 PM
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 3 March 28th 11 08:51 PM
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price valvetom Piloting 0 November 28th 06 02:25 AM
DG-300 water bag valve Q. [email protected] Soaring 1 February 28th 06 03:20 PM
WTB: ASW 27A water valve Peter Van Camp Soaring 0 April 28th 04 10:37 PM
