We're making a new winch drum. The flanges on our drum bent out a little when moving from steel to Spectra line.
I'd like to know the dimensions and structure of any drums/flanges that have failed, or shown signs of failing, and with what length and type of line. Please pass this on to anyone who has details on that. Bret |
On Thursday, December 31, 2015 at 11:05:34 AM UTC-5, Bret Hess wrote:
We're making a new winch drum. The flanges on our drum bent out a little when moving from steel to Spectra line. I'd like to know the dimensions and structure of any drums/flanges that have failed, or shown signs of failing, and with what length and type of line. Please pass this on to anyone who has details on that. Bret Bret, check/join the winchdesign forum. This is a serious issue and it has been discussed in detail on the forum. There is also a great article in a past Soaring written by Scott Fletcher, member of Carolina Soaring, about building the current drum for our winch. There is a lot of engineering and fabrication knowledge that goes into building a winch drum, so it is a task not to be tackled by your average weekend warrior. Uli Winchmeister of Carolina Soaring |
We're making a new winch drum. The flanges on our drum bent out a little when moving from steel to Spectra line. I'd like to know the dimensions and structure of any drums/flanges that have failed, or shown signs of failing, and with what length and type of line. Please pass this on to anyone who has details on that. Bret |
On Thu, 31 Dec 2015 08:05:31 -0800, Bret Hess wrote:
We're making a new winch drum. The flanges on our drum bent out a little when moving from steel to Spectra line. How do you wind the line in before putting the winch away? Once flying has stopped we always pull the lines out to the launch point and then wind them in relatively slowly with no load on them apart from the parachute dragging on the ground and/or inflated and skating along the grass before putting the winch away. This is recommended by Skylaunch. If you simply put the winch away after the last launch(es) the line will be quite tightly wound on the drum(s) and may crush them as the night gets cold. Spectra rope has a fairly high coefficient of expansion (much higher than that of steel cable) and this procedure leaves the rope loose enough that it won't crush the drums when things cool off during the night. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
We're making a new winch drum. The flanges on our drum bent out a little when moving from steel to Spectra line. I'd like to know the dimensions and structure of any drums/flanges that have failed, or shown signs of failing, and with what length and type of line. Please pass this on to anyone who has details on that. Bret Scott Fletcher at Carolina Soaring is an expert on tis topic. UH |
Bret,
You betcha, had three fail. The first was plate welded to a steel automotive rim. That one didn't stand a chance. The second failed when they wound the steel cable on it under tension while hot, and then put it away. The cable cooled down, and crushed the drum overnight. The third one failed due to lack of penetration on the welds. Wrote an article for Soaring about Drum #4. It's not going to fail, got a little carried away with the design, and fabrication of that one. Drum design in our case was highly constrained by the winch design. Second factor is that the forces acting on the drum are way more than you think they should be. Third factor is that Spectra under pressure on the drum flows like a liquid to some degree and this does some really interesting things to the side wall forces. Steel cable is somewhat self supporting which is why you had trouble after switching to spectra. The winch design group is a great place to start. You can get in touch with me directly and I'll see what I can do to help. Drum #4 will be on our winch on the floor of the 2016 SSA convention in Greenville, SC. SF |
Thanks, I'm joining the winch design forum.
SF, I do remember reading your article, but before I was into the problem. I'll look that up. |
Could someone send me the email of the winch design group admin? My request to join has so far gone unanswered. bret dot hess at gmail.
On Saturday, January 2, 2016 at 6:05:23 PM UTC-5, Bret Hess wrote:
Could someone send me the email of the winch design group admin? My request to join has so far gone unanswered. bret dot hess at gmail. Done! Uli |
Thanks! I'm admitted to the club.
Done! Uli |
Best winch metrics - what is the best winch operationally? | Bruce | Soaring | 19 | July 19th 09 11:45 AM |
Azusa drum brakes | Brad[_2_] | Home Built | 3 | January 9th 09 12:53 AM |
2-33 brake drum | [email protected] | Soaring | 2 | June 9th 07 02:22 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Drum dia and torque | Bob Johnson | Soaring | 15 | November 22nd 04 07:37 PM |
