Azusa drum brakes
Old January 8th 09, 03:53 PM posted to rec.aviation.homebuilt
Brad[_2_]
Default Azusa drum brakes
Anyone out there have any experience with Azusa drum brakes?
thanks,
Brad
Old January 8th 09, 06:17 PM posted to rec.aviation.homebuilt
Dear Brad,
First, make sure they are round and that those tiny little shoes make
100% contact -- they need to be radiused to match the drums. Then you
havve to come up with some means of pulling them tight enough, and I'm
talking something on the order of 400 pounds here (!!) This was easy
to get on a go-cart, with a direct link to the brake pedal, the full
strength of your leg to push. Almost impossible to get that kind of
pressure in ANY aircraft installation, which is why most of us end up
going with some sort of hydrulic disk-brake affair. Steve sells a
good one; not too heavy. Be sure to buy the WHOLE KIT... master
cylinders right through to wheels. They're a bit rough in appearance
but function is 100% A-ok. The Azuza are for those of us who are
desperately poor, will probably end up dragging our feet, if that's
what it takes to slow us down. The usual arrangement simply does not
exert enough pressure on the shoes, and the shoes simply do not make a
tight enough fit to the drums.
-Bob
Old January 9th 09, 12:45 AM posted to rec.aviation.homebuilt
Peter Dohm
Dear Brad,
-Bob
Old January 9th 09, 12:53 AM posted to rec.aviation.homebuilt
Peter Dohm
"Brad" wrote in message
thanks,
Brad
Most interesting, and No, I have no experience with them. But I recognize
them from the plans for the KR-2 as the originally specified braking system.
They are obviously much more compact, when sized to fit inside the wheel
rim, than the side mounted disk brakes and were intended to provide the
lowest practical drag for the partially retracting main undercarriage of the
KR-2; but are reputed to provide comparatively inferior braking.
Less obviously; it mounted inside of a pressure recovery type wheel faring
on a fixed undercariage, it would be difficult to find any aerodynamic
difference.
Peter
2-33 brake drum [email protected] Soaring 2 June 9th 07 02:22 AM
FS: Adapters - Azusa Wheel to Bicycle Brake Rotor John A. Landry Home Built 0 March 6th 05 06:04 PM
FS: Adapters - Azusa Wheel to Bicycle Brake Rotor John A. Landry Rotorcraft 0 March 6th 05 06:04 PM
Drum dia and torque Bob Johnson Soaring 15 November 22nd 04 07:37 PM
Opinions on Azusa aluminum wheels/brakes/axles? RTW Home Built 2 July 17th 03 04:19 PM
