trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie
Old April 8th 16, 08:57 PM posted to rec.aviation.soaring
Michael Marshall[_2_]
Default trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie
Hello all,
I have a really good set up that has worked with no issues.
V7 with a IGC LXNav mini box flarm connected to an Oudie 2.
I'm thinking of putting a Flarm view 57 into the panel.
Has anyone else done this?
Best regards,
Michael
Old April 9th 16, 01:18 AM posted to rec.aviation.soaring
son_of_flubber
Default trying to work out how you connect the flarm view 57 to mini boxflarm running a V7 and Oudie
On Friday, April 8, 2016 at 4:00:07 PM UTC-4, Michael Marshall wrote:
Hello all,
Just curious. What does the Flarmview get you that exceeds the V7 Flarm alerts and the Oudie See You Flarm alerts. Can you hook up a speaker to an Oudie 2 and get the voice Flarm alerts?
A Flarm Splitter might get you what you want http://www.aeroshop.eu/en/lx-flarm-splitter.html
Old April 9th 16, 05:56 PM posted to rec.aviation.soaring
waremark
A dedicated screen independent of your Seeyou map scale showing the approximate position and distance of Flarm contacts outside the warning range.
Old April 10th 16, 04:13 AM posted to rec.aviation.soaring
John Orton[_4_]
Hi
Yes it has been done. A way to do it is use a splitter between the V7/S7 and the Flarm as per the diagram in the manual. Ah it seem I can't include the diagram in this post but it is on page 43 of the S7 manual.
On Saturday, 9 April 2016 06:00:07 UTC+10, Michael Marshall wrote:
Hello all,
Best regards,
Michael
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
LXNAV with Flarm doesn't work in US Jonathan St. Cloud Soaring 7 April 14th 15 07:36 PM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
flarm flight log download through Oudie? Matt Herron Jr. Soaring 4 January 21st 15 02:28 AM
FLARM-V7-Oudie setup dbrunone Soaring 10 July 9th 13 08:27 PM
