FLARM-V7-Oudie setup
Old July 7th 13, 06:01 PM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Default FLARM-V7-Oudie setup
Besides mechanical instruments and radio, right now my glider's setup is:
LXNAV Nano -- LXNAV V7 -- Oudie
I'm wondering if I switch it to:
FLARM Brick -- LXNAV V7 -- Oudie
Does anyone fly with this setup?? I don't have panel room for a dedicated FLARM display...the V7 and Oudie can display FLARM data, is that as useful as the dedicated display? In terms of GPS functionality, would I lose anything going to the FLARM over the Nano? Thanks for any info
Old July 7th 13, 07:55 PM posted to rec.aviation.soaring
Matt Herron Jr.
I fly with this setup, and it seems to work well: FLARM Brick -- LXNAV V7 -- Oudie
I also added a FlarmView display. During alerts, it's the flarmview that gets my visual attention. I am new to the arrangement, but I am not sure I would want to fly without a dedicated Flarm display. Its also much better at displaying traffic that is not a threat. Easier to see than the Oudie trails. Its the first thing I glance at when checking (electronically) for traffic. It also has a loud alarm and bright display.
Matt
BTW, thank you for getting Flarm.
is:
info
dbrunone
Old July 7th 13, 08:47 PM posted to rec.aviation.soaring
Tim Taylor
I have a brick (core) with the V7 and the Oudie. The V7 is configured to give warnings as well as the Oudie. I do have a Butterfly display as well.
The V7 and Oudie will give adequate warning but as Matt said, a dedicated display gives better awareness of other non-threat aircraft.
The PowerFlarm works well as a logger and downloads only take a few seconds to a thumb drive.
I am still getting used to the system but like it better as I use it more.
Old July 8th 13, 02:59 AM posted to rec.aviation.soaring
son_of_flubber
Does the V7 change automatically to the Flarm display when there is an alert?
Old July 8th 13, 03:12 AM posted to rec.aviation.soaring
Tim Taylor
It is a setting you can configure. Mine is set to get the radar type warning screen that is the same as the other dedicated displays. Mine comes on at exactly the same time as the Butterfly. I have said that my panel lights up like a Christmas Tree when I get a warning. The V7 and the Butterfly both go into radar mode and the Oudie flashes a red warning banner across the top of the screen.
Old July 8th 13, 10:54 AM posted to rec.aviation.soaring
Pete Startup[_2_]
I use FlarmMouse/V7/Oudie - plug and play, works brilliantly.
I added Flarm LED as I wanted the conflict warning right in front of me
without having to look elsewhere.
Pete
Multiple Battery Setup JohnDeRosa Soaring 33 February 11th 12 02:12 AM
Multiple Battery Setup JohnDeRosa Soaring 0 February 7th 12 04:01 AM
Vario setup brianDG303 Soaring 1 April 3rd 08 05:20 PM
FS 2004 setup Dave Hetteen Simulators 4 June 25th 04 10:40 PM
WX Works setup Paul Tomblin Piloting 16 December 8th 03 04:23 AM
