I have a LX9070 and noticed that when I chose the glider ASG-29E polar, the wing area is listed as 34 sqft and wing loading 2.2 lb/sqft. When I adjust the proper wing area save it and go back to check the data it has reverted to 34 sqft wing area. These should be per-programed polar data. How do I get the correct input?
Thank you |
On Tuesday, 17 May 2016 16:04:46 UTC+2, Jonathan St. Cloud wrote:
I have a LX9070 and noticed that when I chose the glider ASG-29E polar, the wing area is listed as 34 sqft and wing loading 2.2 lb/sqft. When I adjust the proper wing area save it and go back to check the data it has reverted to 34 sqft wing area. These should be per-programed polar data. How do I get the correct input? Thank you Have you asked LXNav for assistance? They usually respond within a day or two. This is a real stab in the dark but did you try renaming the glider? Maybe the code keeps loading the default pre-loaded polar for your glider because the names match and by changing the glider name to something else it will save your settings to a different internal "glider profile"? |
LX-Nav S80 settings | Mark628CA | Soaring | 11 | July 8th 16 08:11 AM |
Lx9070 V80 and Butterfly electronic and pnuemantic compensation | Jonathan St. Cloud | Soaring | 2 | May 5th 16 06:47 PM |
Nav radio settings in FMC | Mxsmanic | Piloting | 5 | January 10th 07 08:39 PM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
L-nav Settings Ventus 2ct-18 | Oliver Peters | Soaring | 4 | July 18th 03 04:14 AM |
