ATC Altimeter Settings
Old April 1st 05, 07:13 PM
O. Sami Saydjari
Default ATC Altimeter Settings
When entering an ATC region, we often get an altimeter setting, usually
at some fix. So for example, when entering the Chicago center ATC
region, they say something like, "Midway altimeter is xx.xx." I have
some questions.
1. So, do they pick some fix for the region and give everyone (those
below FL 180) the altimeter of that fix? Do they break up into
sub-regions and give everyone in that sub-region that same fix altimeter
setting?
2. At what point after departing an airport do you change altimeter
setting to the one supplied by ATC? Similarly, on approaching an
airport to land, at what point do you switch over to the altimeter
setting of the airport (from that given by ATC).
The reason I ask is that sometimes, the altimeter settings can be quite
different. Especially if there is VFR traffic around an airport, it
seems that there is some risk if everyone entering the pattern (or
approaching the pattern) does not share the same altimeter setting.
Just curious.
-Sami
N2057M, Piper Turbo Arrow III
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 10:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 03:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 08:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 10:28 AM
Altimeter experience HankC Piloting 2 July 25th 03 10:43 PM
