I have always used Simtec's 4981 white patching paste to repair small dings and minor cosmetic divots. However I use such small amounts over long periods of time, nearly the entire quart eventually turns to rubber and has to be trashed.
I am looking for a lower quantity solution to avoid wasting so much material and cash. White is a must and MEKP catalyst is preferred but I am flexible on that. Any suggestions? Paul ZZ |
For very small dents, you could use cold enamel for repairing bathtubs, kitchen stoves etc. Available in small bottles (20 ml). Not really kosher, but...
http://www.ditmer.nl/EN/Enameling/Ca...old_enamel.htm |
West Marine sells a patching paste. I have used it in the past for mid-season minor dings. With careful wet sanding and polishing it makes a pretty invisible repair.
http://www.westmarine.com/buy/west-m...-kit--14153282 |
On Monday, July 4, 2016 at 4:16:34 PM UTC-5, ZZ wrote:
I have always used Simtec's 4981 white patching paste to repair small dings and minor cosmetic divots. However I use such small amounts over long periods of time, nearly the entire quart eventually turns to rubber and has to be trashed. I am looking for a lower quantity solution to avoid wasting so much material and cash. White is a must and MEKP catalyst is preferred but I am flexible on that. Any suggestions? Paul ZZ This looks interesting from West Marine: http://www.westmarine.com/buy/west-s...04_120_001_508 |
On Tuesday, July 5, 2016 at 2:26:41 PM UTC-4, CLewis95 wrote:
On Monday, July 4, 2016 at 4:16:34 PM UTC-5, ZZ wrote: I have always used Simtec's 4981 white patching paste to repair small dings and minor cosmetic divots. However I use such small amounts over long periods of time, nearly the entire quart eventually turns to rubber and has to be trashed. I am looking for a lower quantity solution to avoid wasting so much material and cash. White is a must and MEKP catalyst is preferred but I am flexible on that. Any suggestions? Paul ZZ This looks interesting from West Marine: http://www.westmarine.com/buy/west-s...04_120_001_508 Good for your boat or trailer, but stick with the good stuff for glider repairs. UH |
On Monday, July 4, 2016 at 2:16:34 PM UTC-7, ZZ wrote:
I have always used Simtec's 4981 white patching paste to repair small dings and minor cosmetic divots. However I use such small amounts over long periods of time, nearly the entire quart eventually turns to rubber and has to be trashed. I am looking for a lower quantity solution to avoid wasting so much material and cash. White is a must and MEKP catalyst is preferred but I am flexible on that. Any suggestions? Paul ZZ You can extend the life of your 4981 by keeping it in the freezer. Best to let it warm a bit before opening so you don't get condensation in the can. Craig 7Q |
Seems like a business opportunity for someone who knows this stuff and can write...
Down package the good stuff to make a glider ding kit. Everyone gets little dings now and then. Quantities can be quite small to make the kit affordable. Include comprehensive instructions. |
Europe surface-to-surface - File 16 of 25 - germany panzerfaust cutaway.jpg (1/1) | Smaug Ichorfang | Aviation Photos | 0 | October 28th 07 03:21 AM |
Europe surface-to-surface - File 02 of 28 - england nlaw kestrel 0.jpg (1/1) | Smaug Ichorfang | Aviation Photos | 0 | October 27th 07 06:15 PM |
Zink Chromate Paste | Michael Horowitz | Home Built | 3 | January 3rd 07 01:57 PM |
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? | jls | Home Built | 3 | February 3rd 04 12:15 AM |
best cutting fluid/oil/paste 2004..... theory and practice? | B2431 | Home Built | 1 | January 20th 04 06:27 PM |
