Zink Chromate Paste
Old January 2nd 07, 02:46 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Zink Chromate Paste
Duralac Zinc Chromate Paste doesn't appear in the Spruce or Wick
catalog, apparently for health reasons.
I do see it mentioned for sale by marine stores.
Has anyone using an acceptable substitute, easier to locate? - MIke
Old January 2nd 07, 08:20 PM posted to rec.aviation.homebuilt
jls
You can buy aerosol spray cans of zinc chromate paint from ACS. It is
cheap and effective. Don't breathe it. I think the chromium is
hexavalent, i. e., toxic. A light film on aluminum surfaces you wish
to protect is sufficient.
I doubt zinc chromate is effective with steel as it is with aluminum.
Tony Bingelis says that it is not, iirc. I bead-blast the corrosion
from steel, then coat it with an epoxy etch primer, followed with a few
coats of a durable paint like PPG durathane or a Sherwin Williams
polyurethane.
If you're covering the aluminum with polyester fabric, don't forget to
over-coat the zinc chromate with a primer like epoxy to prevent
bleeding when you use polyester covering chemicals like polytak,
polybrush, and polyspray. They contain methyl ethyl ketone which will
dissolve the zinc chromate paint, and it will bleed into your fabric.
Old January 3rd 07, 03:16 AM posted to rec.aviation.homebuilt
John P Kimmel
Proseal.
John Kimmel
GET YER STINKING PAWS OFF ME YOU DAMN DIRTY APE!
Old January 3rd 07, 01:57 PM posted to rec.aviation.homebuilt
Stealth Pilot
On Tue, 02 Jan 2007 09:46:49 -0500, Michael Horowitz
if you can get it in marine stores then get it in marine stores.
duralac is duralac is duralac.
there is no substitute for duralac nor is there any need to be.
btw in perth in australia I can buy duralac in every pilot shop on
jandakot. ...and at marine stores.
Stealth Pilot
Zink vs Lowlands Cup Ian Soaring 3 December 15th 06 01:57 PM
Are you buying the calendar of Claus Dieter Zink this year? [email protected] Soaring 5 December 15th 06 01:57 PM
Claus-Dieter Zink takes measures against Lowlands Cup team Peter Millenaar Soaring 57 January 9th 06 09:50 AM
Zinc Chromate in 2005 Michael Horowitz Home Built 4 October 16th 05 06:44 PM
Update: Segelflug and Zink Calendars from Knauff and Grove Steve Soaring 1 December 21st 03 12:43 AM
