In general, how different are the fittings in a Cobra trailer for
different makes and models of gliders, 15M and Standard class? For example, what changes would be required to put an ASW20 into an ASW28, or Discus, or Ventus rigged Cobra trailer? Thanks for any advice, John |
John,
I have done what your proposing a couple of times and for the most part, it is straight forward. All the fittings are adjustable and everything should work out fine. I would check the height of the wing dolly to see if it is correct for the new wing. All the stops are adjustable and so is the nose cone, both height and length.You may have to move the tail wheel (skid) bracket in the floor.Give me a shout, if you run into trouble. JJ Sinclair |
FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 04:47 PM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
Need (glider&) trailer transport - Sante Fe, NM > Santa Cruz, CA, late Aug | Eric | Soaring | 1 | August 8th 03 03:21 PM |
Glider trailer towing | Jeff Landfield | Soaring | 0 | July 21st 03 04:25 AM |
