I wish I'd never got into this...
Old September 11th 03, 08:27 PM
Kevin Neave
Default I wish I'd never got into this...
The original question stated a glider doing 100kts
with/without 100kgs of ballast.
Ignoring the stalling speed for the moment, Does anyone
out there think the pull-up takes more than 4 or 5
seconds?
Does anyone out there think that the sink rate of the
unballasted glider at 100kts is more than 1m/s greater
than the ballasted one?
Finally does anyone out there think that the difference
in height gain for the ballasted glider is more than
4 or 5 metres?
If you think the answer to the third is Yes but the
answer to the first & second is No, please let me know
why!!
And if your answer to 'Why ?' is ''cos I've done pull-ups
higher with ballast' I want to know exact entry speed,
exact exit speed, climb angle, exact amount of ballast,
and exact heights gained with & without ballast (preferably
backed up with a logger trace!).
(And NO comparing two different gliders, just 'cos
they have the same wing section & are doing rolling
manoeuvres during the pull-up doesn't count)
Kevin
Old September 12th 03, 02:19 AM
Kirk Stant
Kevin,
What we appear to be seeing here is how strong preconceptions and/or
expectations can override actual events. I could have sworn I would
get a better zoom with ballast, but I now realize that it doesn't make
sense. And I know all about Gallileo's experiment - I surprized my 15
year old daugher with it just a few weeks ago. But not having put
much thought into it, I didn't connect the two. Amazing, you can
learn something on RAS, occasionally!
It would be fun to poll the general soaring population about this - I
asked a really good pilot friend about this and his immediate answer
was "Of course you will go higher with water".
Now, I still have a gut feeling that there are some other forces
acting that make it seem that a ballasted pullup goes higher - because
it sure feels like it does!
Must have something to do with Flat Earth Theory....
Kirk
66
Old September 12th 03, 08:59 PM
Chris OCallaghan
Kevin,
the problem isn't wholly ballistic. That is, it's not quite the same
as firing projectiles of different mass straight up at the same
initial speed. Remember, your sailplane has drag that varies with
speed. Additional mass reduces total drag at higher speeds. That's why
we carry water ballast when racing. Thus, during your pull up, the
ballasted glider will have less drag than the unballasted one, and
will therefore gain additional altitude. Is it alot? No. But
significant.
On a side note, Galileo never dropped objects off the tower of Pisa.
Though he did some work with inclined planes, he recognized that
friction would skew his results (think of dropping a ping-pong ball
next to a golf ball...), and Catholic dogma didn't leave much room for
fault when it came to heresy. Instead, he created a thought
experiment. He postulated that if heavier objects fall faster, a heavy
object tied by a string to a lighter object and thrown from a tower
should pull the lighter object faster, and the lighter object would
impede the acceleration of the heavier one. However, once tied by a
string, they were a single object of greater mass and should therefore
outpace the individual objects. This demonstrated the fallacy of the
argument for "greater attraction" and saved him the embarrassment of
having to demonstrate a flawed experiment to anti-empiricists.
Old September 15th 03, 04:55 AM
Kilo Charlie
I just entered this thread so apologize if having not read all the posts
this has been mentioned already. Let me quote Helmut Reichmann from Cross
Country Soaring pp 63-64:
"Starting in contests with full water ballast is always a good idea. If the
run through the gate is made at high speed, heavier sailplanes will gain
more height than light ones in the subsequent pullup".
Although I find it impossible to argue with the math presented might it be
that we are oversimplifying things? With all due respect a modern sailplane
is a long way from a rock or pendulum. I'm certainly not an engineer but
have flown for long enough and have done enough high speed pullups at the
finish and on course to feel fairly certain that the altitude gained is
substantially greater. But even more to the point if you don't believe this
then was Reichmann wrong? Maybe the translation was poor? Geez my bubble
is bursting! Send help!
Casey Lenox
KC
Phoenix
Old September 15th 03, 04:05 PM
Andy Blackburn
If I look at my '27's polar and assume it takes about
0.25 nm to execute a pullup, I get less than 25 feet
of difference due to the higher sink rate at redline
for the unballasted case (at 154 kts the ballasted
L/D is 19 and unballasted L/D is 14).
This doesn't count for the losses associated with the
Gs of the transition to the pullup, but I would think
that you'd generate more induced drag to change the
(vertical) direction of the heavier glider.
I, too, have always flown with the belief that ballasted
gliders would get more altitude on a pullup from the
same speed - but I can't come up with any aerodynamic
or physics rationale to support it.
9B
read all the posts
'Starting in contests with full water ballast is always
a good idea. If the
more height than light ones in the subsequent pullup'.
a modern sailplane
not an engineer but
altitude gained is
Casey Lenox
KC
Phoenix
Old September 15th 03, 11:57 PM
Chris OCallaghan
Andy,
see my notes earlier in the thread. There's not much penalty for
pulling from high speed so long as you don't go to too quickly to high
AOA (bigger penalty in induced drag). 2g to 30 degrees nose up is
typical. The you ease off to 1g until you start push gently to
attitude at your desired exit speed.
Did your calculations include the losses to friction throughout the
manuever? Your altitude difference seems a little too low. I would
expect about a 20 to 30 foot difference for a pull from 100 knots to
60 knots, ie, a normal "test the strength of the core" pull up.
At any rate, if we get any decent weather, I'll be sure to make some
runs with a lighter glider and tender the real world results.
The original poster was looking for some real world feedback. Right
now all I can offer is that when ridge soaring, if I have water and
another 27/V2 is empty, I'll outpace him by at least 10 knots on a
hundred mile-per-hour day. Roughly 10 to 12 percent more speed at the
same sink rate/drag. A big spoonful of pure, sweet hubris.
Old September 15th 03, 09:44 PM
Derrick Steed
I'd like a bash at this:
Can we get some assumptions out in the open first...
And before I get toasted, I am not being patronising, I just like to get
assumptions clear and out in the open.
1. throughout we stick to one glider type which is, e.g.
i) why? because it would be like comparing apples and oranges otherwise
ii) so, lets assume it is an asw23, or it is a pik20b, or ...
ii) consider two cases: ballasted (= greater mass) and unballasted
iii) otherwise, the configuration of the two gliders is identical except for
the amount of ballast they are carrying
2. potential energy = mass x gravitational acceleration x height, so
i) for a given height the ballasted glider has more potential energy than the
unballasted glider
3. kinetic energy = 1/2 x mass x speed x speed, so
ii) for a given speed the ballasted glider has more kinetic energy than the
unballasted glider
4. total energy = potential energy + kinetic energy
i) from the above we now know that, for a given height and speed, the
ballasted glider has a greater total energy than the unballasted glider
5. from the gliders polar and the basic arithmetic of ballasting we know that,
above a certain speed (i.e. the speed at which the sink rates of both the
ballasted and unballasted gliders are the same), the ballasted glider will be
travelling faster, for a given sink rate (= rate of energy loss), than the
unballasted glider, below that speed the unballasted glider will be losing
energy at a lower rate than the ballasted glider
i) this effect is due to the increase in the wing loading of the glider
ii) the same effect would apply (approximately, because the wing bending
would be somewhat different) to the unballasted glider in accelerated flight
(e.g. during a pull up)
iii) assuming the above, for a given speed the ballasted glider will be
sinking at a lower rate than the unballasted glider (e.g. the rate of energy
loss is lower) - don't believe me? look at the polar
6. provided we stay above that "certain speed" (which is determined by the
wing loading and so will be higher if the wing loading is higher)
i) for a given speed the ballasted glider will always be losing (potential)
energy at a lower rate than the unballasted glider
ii) this will be true regardless of whether the glider is in steady (i.e.
straight line) flight or in accelerated (e.g. turning or pulling up) flight
iii) in fact the difference in the rates of loss will be even greater in
accelerated flight
So far, so good (I hope). Now lets ignore the glide segment and just consider
the pull up and the subsequent zoom.
7. for two real gliders, of the same type, same configuration, one ballasted
more than the other, during the pull up
i) assuming the two gliders start at the same height and the same speed
ii) both gliders increase their wing loading in the same proportion to their
mass during the pull up
iii) I think that, given ii, they will follow the same pull up curve as a
result, but
iv) throughout the maneuvre, the ballasted glider will be losing energy at a
v) so it should come out of the pull up higher and having lost less energy
than the unballasted glider (i.e. it will start the zoom faster than the
unballasted glider)
8. during the zoom (at zero g), if both gliders started at the same height and
speed
i) both will gain potential energy, and
ii) both will lose kinetic energy, but at a rate proportional to their masses
due to the effect of gravitational acceleration, and so
iii) the gliders would rise to the same height if they were in a vacuum
throughout, but
iv) they are not in a vacuum, they are gliding (probably at a reduced wing
loading), so
v) provided they are flying above that "certain speed", the ballasted glider
will be losing energy at a lower rate than the unballasted glider, and so it
will zoom higher
I admit this is a somewhat qualitative argument, so would someone like to put
figures on it?
Rgds,
Derrick.
Old September 16th 03, 08:32 AM
Andy Blackburn
Hey Chris,
I used the factory polar to estimate altitude loss
at redline with and without ballast. The difference
over 0.25 nm was 26' (105' - 79'). As you bleed off
airspeed the difference in sink rate declines, so the
actual difference in altitude loss should be less than
25' - maybe more like 15'.
This ignores G-related losses, which should be low
if the Gs are low (i.e. not too radical a pullup).
Of course too gradual a pullup and you don't get maximum
altitude gain because the parasite drag will accumulate.
9B
At 23:00 15 September 2003, Chris Ocallaghan wrote:
Andy,
penalty for
too quickly to high
nose up is
gently to
throughout the
low. I would
from 100 knots to
60 knots, ie, a normal 'test the strength of the core'
pull up.
sure to make some
results.
feedback. Right
I have water and
10 knots on a
more speed at the
hubris.
