I am shopping for a glider. Today I looked at a 304 That is in very good shape, current on its annual. The type is experimental. The certificate in the cockpit stipulates that the glider is to be operated from a single airfield. Is this normal? Will faa hassle me were I to purchase and register it and wish to fly out of a different field? Do airworthiness certificates typically specify that an aircraft only fly out of one location?
Many thanks for any enlightenment. |
You'll need to submit a Program Letter to your local FSDO. This letter
will describe the ship, list its home field (your base of operations), the types of flights planned, i.e., "fly at the Seniors Competition", 30 practice flights of 4 hours duration to maintain currency, etc. You can work out with your FSDO representative what is required in your letter. You'll have to submit a new letter each year. It's not a big deal. Send me your email address and I'll send you a copy of letter which worked for my experimental glider. Dan On 2/4/2017 7:01 PM, Del Jensen wrote: I am shopping for a glider. Today I looked at a 304 That is in very good shape, current on its annual. The type is experimental. The certificate in the cockpit stipulates that the glider is to be operated from a single airfield. Is this normal? Will faa hassle me were I to purchase and register it and wish to fly out of a different field? Do airworthiness certificates typically specify that an aircraft only fly out of one location? Many thanks for any enlightenment. -- Dan, 5J |
No need to send your email - I emailed you a copy of a previous Program
Letter to update to your needs should you buy the glider. On 2/4/2017 7:24 PM, Dan Marotta wrote: You'll need to submit a Program Letter to your local FSDO. This letter will describe the ship, list its home field (your base of operations), the types of flights planned, i.e., "fly at the Seniors Competition", 30 practice flights of 4 hours duration to maintain currency, etc. You can work out with your FSDO representative what is required in your letter. You'll have to submit a new letter each year. It's not a big deal. Send me your email address and I'll send you a copy of letter which worked for my experimental glider. Dan On 2/4/2017 7:01 PM, Del Jensen wrote: I am shopping for a glider. Today I looked at a 304 That is in very good shape, current on its annual. The type is experimental. The certificate in the cockpit stipulates that the glider is to be operated from a single airfield. Is this normal? Will faa hassle me were I to purchase and register it and wish to fly out of a different field? Do airworthiness certificates typically specify that an aircraft only fly out of one location? Many thanks for any enlightenment. -- Dan, 5J |
Many thanks Dan. I was little bit concerned over whether I could take the glider somewhere on an occasional basis (e.g., Parowan). You've set my mind at ease.
Del |
On Saturday, February 4, 2017 at 8:18:00 PM UTC-8, Del Jensen wrote:
Many thanks Dan. I was little bit concerned over whether I could take the glider somewhere on an occasional basis (e.g., Parowan). You've set my mind at ease. Del I am pretty sure a program letter won't override any limitations in the airworthiness certificate. You need a new airworthiness certificate. But I could be wrong . . . |
On Sunday, February 5, 2017 at 12:01:36 AM UTC-5, wrote:
On Saturday, February 4, 2017 at 8:18:00 PM UTC-8, Del Jensen wrote: Many thanks Dan. I was little bit concerned over whether I could take the glider somewhere on an occasional basis (e.g., Parowan). You've set my mind at ease. Del I am pretty sure a program letter won't override any limitations in the airworthiness certificate. You need a new airworthiness certificate. But I could be wrong . . . You are right that the program letter does not override limitations in the AW certificate and associated docs. Whether a new AW certificate is needed depends on what the old one says. If it is very old you may not have to do a program letter and can fly most anywhere. After the California jet fighter crash the Feds tightened up a lot. |
Thanks for the heads up on that. Do you know of a link or reference to the guide document?
Del |
A specific place is required for phase one testing.
Glad to have been of assistance.
On 2/4/2017 9:17 PM, Del Jensen wrote: Many thanks Dan. I was little bit concerned over whether I could take the glider somewhere on an occasional basis (e.g., Parowan). You've set my mind at ease. Del -- Dan, 5J |
On Saturday, February 4, 2017 at 9:01:45 PM UTC-5, Del Jensen wrote:
I am shopping for a glider. Today I looked at a 304 That is in very good shape, current on its annual. The type is experimental. The certificate in the cockpit stipulates that the glider is to be operated from a single airfield. Is this normal? Will faa hassle me were I to purchase and register it and wish to fly out of a different field? Do airworthiness certificates typically specify that an aircraft only fly out of one location? Many thanks for any enlightenment. Assuming it is licensed Experimental- Exhibition and Air Racing you should be able to get your local FSDO to provide new operating limitations that conform to the latest standards. Operating limitations are a prt of the airworthiness certificate. Current standards allow for operating at sites other than home base as long as they are on your annual program letter. UH |
FAA Revoking Standard Airworthiness Certificate DG-505 | NG | Soaring | 32 | February 16th 17 02:23 PM |
Export certificate of airworthiness | Greg Arnold[_2_] | Soaring | 2 | December 27th 10 06:10 AM |
Airworthiness Certificate Replacement? | [email protected] | Soaring | 6 | June 26th 08 07:11 PM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
Exhibition/Racing Airworthiness Certificate Question | bsquared | Soaring | 5 | June 22nd 04 06:24 PM |
